URGENT Assistance: Socket Open Failed
Hi,
I need an urgent assistance please. I having an issue wherein I could login to my ISY console. I though I had a problem with the SD card so I replaced it but still the same case - as per this link below.
http://forum.universal-devices.com/topic/9683-frequent-socket-open-failed-javanetsockettimeoutexception/
I could also telnet. I tried reformating the old SD card but to no avail.
Please let me know if there's a resolution to this.
Edited by ferdies
Have a look at this thread... typically it seems the issue is related to failing PLM..
Edit: likely you'll need to contact support for help with this.
Jon...
Edited by jerlands
Jon...
Thanks for the reply.
I have tried using 2 PLMs and connected ISY directly to the router and still the problem persists.
Hi,
Is there a way to factory reset ISY from telnet? That's the only way I can connect to the device.
THanks.
Hi,
THanks.
Yes, you might as well give it a try :)
Instructions in the wiki... FR command
Jon...
