January 7, 201610 yr I understand that the VRCS4-M0Z isn't compatible with the ISY (because it's multichannel), but I noticed that it appears to show up on my Vera UI after I attempted to pair the device. Note that my Vera is set as a secondary controller. Is it possible that my Vera could allow me to control devices, even though the ISY doesn't support this particular device? I'm not really sure how zwave primary and secondary devices relate, and if this is even feasible. Thanks!
January 7, 201610 yr Author Awesome, thanks Michel! So, I noticed that not all devices aren't getting sync'ed from my ISY to my Vera, so I'm attempting to exclude it and re-include it for troubleshooting purposes. Oddly enough, a few devices are in there, but definitely not all of them. Could you give me a little more detail as to the steps required for doing this? Once my Vera is properly setup as a secondary controller to my ISY, would I then include the VRCS4 to my ISY and watch it get sync'ed to my Vera? Or would I include it from my Vera? Thanks!
January 8, 201610 yr Hi jon102034050, If they are not showing up, something is wrong. I am not familiar with Vera so what you need to do is to find the function that "imports existing network". For instance, in ISY, this is achieved by: http://wiki.universal-devices.com/index.php?title=ISY_Z-Wave_GenII_-_Instructions#Importing_an_Existing_Z-Wave_Network Once your Vera is secondary, then it does not matter where you include devices because the primary is in charge of node/id assignments. With kind regards, Michel
January 8, 201610 yr Author Hi jon102034050, If they are not showing up, something is wrong. I am not familiar with Vera so what you need to do is to find the function that "imports existing network". For instance, in ISY, this is achieved by: http://wiki.universal-devices.com/index.php?title=ISY_Z-Wave_GenII_-_Instructions#Importing_an_Existing_Z-Wave_Network Once your Vera is secondary, then it does not matter where you include devices because the primary is in charge of node/id assignments. With kind regards, Michel Thanks for the instructions - I was able to get the devices to show up in my Vera after removing it and re-adding it as a secondary controller (the import existing network was just timing out for some reason....). Now the only issue I'm having is with my crappy Vera, and getting it to actually run scenes when the buttons are pressed
January 11, 201610 yr Author I'm going to quote a forum response from another forum because I found out what was going on there. Basically, I thought that the zwave was getting paired to my ISY OK because the pairing prompt was disappearing, but no device was showing up (I just figured because its a multi-function device, this was how it would show up...). I had to exclude it and include it with the following steps (note, this was performed with a Vera, the same steps apply for an ISY): I remember it was tricky as you needed to initiate the include/exclude process on the device first BEFORE initiating on the vera. I also remember having to leave the vera near the controller for a few minutes after including with low power. I bet that is your solutionDo as followsReset the controller first to be safe Hold 1&3 for 10 seconds (will flash amber then red) release buttons. Controller should be reset.Bring vera within a couple feet Press and hold button 1 and 3 After controller is flashing amber let go.Go to vera and place in exclude mode.After exclusion hold button 1&3Controller should be flashing amber againGo to low power include.Should find device and add... wait another 5 minutes before moving vera. After including it to the ISY in this manner, I was able to make my Vera a secondary controller, and the VRCS4 showed up just fine in my Vera interface. I'm then able to create scenes with it using the Vera (rather than my ISY). Hopefully this may help somebody in the future, it took me a very long time to figure this out, but it's cool it works as anticipated now! Again, thanks Michel, I really appreciate the help!
March 29, 201610 yr I'm trying to do basically the same thing as posted above, except I'm trying to add a GE Keypad Controller, Model ZW5301. This is a Secondary Controller Only which supports: Basic ZWAVE Command Set Binary Switch Command Class Controller Replication Command Class Multi-Level Switch Version 1 Command Class When using Basic Command Class to control devices the controller will either transmit a value of 0 or 99, depending on the button Pressed. The instructions say I'm to put the Primary Controller into Transfer Mode so it sends information to the Secondary Controller. I looked at the Wiki and Posts above and can't seem to find that mode. Unless, you use "Learn Mode"? But, that seems to be wanting to Learn from the Secondary Controller, not the other way around. I was able to include the device, and it shows up as a Remote Switch, but I can't do anything with from there. Any help would be greatly appreciated. I'm using FW 4.3.26. Edited March 29, 201610 yr by erkorb
March 29, 201610 yr Hi erkorb, This is not the same thing. Your device is a switch which requires multi channel support currently available in 5.0.x branch which is still alpha. We were going to have another release last week but found a bug which is already fixed and we are testing as we speak. With kind regards, Michel
March 30, 201610 yr Thanks @Michel - Waiting patiently for Multi-channel support. patiently but anxiously....lol
