Insteon Skylink motion sensor off-timer
My understanding is that houselinc 2 is able to modify the off-timer for the skylink 2420 insteon motion sensor.
Can the ISY-99i do this? if so, how? if not, when will it be able to do so and what is the best work-around?
Hello someguy,
Yes, you can do it in ISY releases 2.6.12/13:
1. Click on one of the motion sensor nodes
2. In the right pane, at the bottom, you see a button called Set Options
Hello someguy,
For clarification, you should also know that Motion Sensor is an RF device which goes to sleep mode. The only way you can communicate with RF devices that go to sleep mode is to put them into programming mode. As such, you will have to first click the set button on the MS till the light starts blinking and then retry.
I tried this and it didn't work. here is where I suspect that most of the discussion about this will be:
http://forum.universal-devices.com/view ... 4453#14453
