September 27, 200718 yr I am trying to make a bathroom morning scene, but not having any luck. Here is what I have tried. 'Master Bath Light - Morning' is a button on a KPL. I have tried it in both toggle and non-toggle. If Control 'Master Bath Light - Morning' is Off {or On... I have tried both} Then Set 'Master Bath Light' 20% Set 'Slow Master Bath Light' On {This is a scene with Master Bath Light set to a 5 minute ramp rate} Wait 1 hour Set 'Master Bath Light' Off {Just in case I left it on for more than an hour} Finally Set 'Master Bath Light' Off {Just in case I turn off this scene before the hour is up} Once I can get this to work, I will add the bath fan to this routine. What I am trying to do is to have a button on this KPL that will turn the light on at a low level... then start a long ramp from there. A long ramp from 0 is not an option. I then will have some timers in there for maximum time for the lights and timing of the fan.
September 27, 200718 yr What happens now when this program runs? In know for some Insteon devices, if you send them an 'On' command, and then another (possibly different) 'On' command then this second one will be ignored if the first hasn't finished. You might want to try adding a 1 second wait after setting it to 20%, or adding a 'Brighten' between them.
September 27, 200718 yr Author Nothing happens. The scene doesn't even appear to be triggered. The button on the KPL is acting like a non-toggle where it flashes a couple times and returns to the original state (off) even when the ISY says that this is a toggle button.
September 27, 200718 yr Nothing happens. The scene doesn't even appear to be triggered. The button on the KPL is acting like a non-toggle where it flashes a couple times and returns to the original state (off) even when the ISY says that this is a toggle button. Might want to reset the device or try to manually get that button out of toggle mode. Which reminds me - I'd still like the ability to change the toggle mode on the load buttons of a KPL when in 6-button mode. With the current firmware, this has to be done manually at the switch.
September 28, 200718 yr Hi Mike, Apologies for a tardy reply. It will be implemented, for sure, in the final release of 2.5. Unfortunately, it will not be part of next code drop. With kind regards, Michel Nothing happens. The scene doesn't even appear to be triggered. The button on the KPL is acting like a non-toggle where it flashes a couple times and returns to the original state (off) even when the ISY says that this is a toggle button. Might want to reset the device or try to manually get that button out of toggle mode. Which reminds me - I'd still like the ability to change the toggle mode on the load buttons of a KPL when in 6-button mode. With the current firmware, this has to be done manually at the switch.
