Java 8 update 71, now scenes commands not working
hi, i upgraded Java 8 two days ago and everything seems to be ok.
Today, i installed two micro switch modules and to my surprise i can not get them to work using scenes commands. they work if i trigger them using the admin on and off feature on devices but when i make a scene and i include an action command to turn on or off nothing happens.
This is the event viewer level 3 when i send the command from devices (works fine)
Thu 01/21/2016 06:44:54 PM : [iNST-TX-I1  ] 02 62 32 A8 88 0F 11 FF
Thu 01/21/2016 06:44:54 PM : [iNST-ACK    ] 02 62 32.A8.88 0F 11 FF 06          LTONRR (FF)
Thu 01/21/2016 06:44:55 PM : [iNST-SRX    ] 02 50 32.A8.88 3B.97.4B 2F 11 FF    LTONRR (FF)
Thu 01/21/2016 06:44:55 PM : [std-Direct Ack] 32.A8.88-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Thu 01/21/2016 06:44:55 PM : [D2D EVENT   ] Event [32 A8 88 1] [sT] [255] uom=0 prec=-1
Thu 01/21/2016 06:44:55 PM : [  32 A8 88 1]       ST 255
​and this is the event viewer level 3 when i force the module to turn on using the scenes command  (nothing happens)
Thu 01/21/2016 06:45:43 PM : [        Time] 18:45:45 14(0)
anybody has any idea what is going on? i already clear the Java cache and reinstalled the isy admin applet but it still not working .
FYI: i am using firmware and UI  version v.4.3.26
I had some problems with this java version also. The system with the problems is Win 10 x32.
I had programs missing at random throughout the admin console. Other programs linking to the missing ones showed the <undefined> text in the program lines. I almost started patching programs to make things work but the job would have been massive and taken months to patch together.
I went to another PC Win 10 x64 and ran admin console...everything was still there so I knew ISY was OK....backed up again.
...back to the Netbook x32, I did the 'java delete everything' one more time, and after finally reloading the Admin Console java file everything loaded fine again.
I have to conclude some admin console setup is based on the java version and wouldn't run with the java upgrade.
So much for package independence and standard hooks!
I agree with Michel.. I just tested about 8 scenes that include Micro Modules on a 32-bit Windows 10 machine with Java  8 update .71 and had 100% success. Try Restore Device and/or Write Updates to Device or clearing the Java cache as suggested by larryflix.
i had cleared the java cache 3 times using "java deleting everything" with no luck. i guess the only option now is to use Restore Device.
Did you delete the Admin Console applet along with the java cache/file  clearing?
I always move my installed Admin Console applet to another directory on my desktop. When the java cache is cleared, with all three checkboxes filled, it doesn't delete the moved applet as it doesn't know where it has gone. I figure the applet must have  some specific setup information inside, or associated with it, from the bad installation and it needs to be deleted also so that a fresh initialisation will be done and possibly work correctly this time.
i did deleted the applet as well and i had to download a fresh one and re-install.
well, i restored the devices and still no working.
What type of load is your module(s) hooked up to?
I'm using the latest version of Java without any issues
