Test Insteon Thermostat and send notification if not responding
I'm looking to put in a fail safe if my insteon thermostat stops responding or working. It currently works fine but I still would like to query it and if it doesn't respond, then send a notification.
I've tested a few programs and they don't do anything. I think it's because the if statement is a simple status statement.
I have:
Status 'Furnace - Main' is not responding
Send Notification to 'My Message' Content 'Thermostat Failure'
I tested this on a lamplinc module and unplugged it. Nothing happened.
I read a bit and seems like a if statement with a simple status statement simply won't run.
Any Ideas?
A "status" change requires some sort of event to trigger the change -- and clearly the failed or unplugged device can't send a signal to trigger the change.  So, instead, you'll need to arrange for the ISY to periodically query the devices, so that it forces a status update, or changes the status to "not responding" if the device is missing or failed.
The ISY does this once per day at around 3AM usually -- probably not good enough for your purposes.  So, simply create your own program that queries the devices in question several times an hour or so.
Edited to add:  You can't query a battery-powered device, so I hope your thermostat is powered!
I actually do have a query program for the thermostat.
It is:
If:
From 12:00:00 AM
For 24:00 hours
Repeat Every 15 minutes
Set 'Furnace - Main' Query
Is this what you mean? If not, if you could provide an example, I'll give it a try
I don't know what to do from here. I assume I should set a variable to something and then another program to watch that variable? ...Seems like it may work but I'm missing the piece between the query and the notification.
This is a standard Insteon thermostat. Not battery powered. Wired with C wire (24vac).
Edited by EddieRock
I am not sure how you would do this as I have never used queries  for devices.
You could run a timeout program that the humidity update keeps reset but that would depend on the humidity changing constantly.
A long timer could be used to perform this but may not work perfectly. If the humidity sensor sends the same RH every time the program will not get triggered,
     humidity >= 0    <---- just this may be enough to trigger the Wait reset
  Or
    temperature >= 0
 Or
    heat contact is switched  'On'
 Or
    cool contact is switched 'On'
    Wait  60 minutes
    Send a notification 'Stat comm failed'
I have been tracking and controlling my humidity here for the last month and it wiggles and bobbles continuously but I am mechanically attempting to keep it constant. Opening a door for 5 minutes causes a drop for about 3-4 hours. It's below 0 C here and very dry when the air is heated inside.
