Suggestion: Code formatting
I have noticed in the Admin Console that the code is not evenly indented it is also noticeable in the code pasted in other posts. Also the more than one spaces in code is sometimes a bit wierd too. Could it be tweaked to use 4 or 5 spaces per nesting and nix the extra spaces?
First example:
   Status AC is Off
   And (
       Time is 5:00PM
       Or Time is 4:00PM
       And Temp > 90
   Set AC on
Another example:
   On Mon, Tue, Wed, Thu, Fri
   From 9:00:00AM
   To 5:30:00PM (same day)
   Or On Sat
   From 10:00:00AM
   To 2:00:00PM (same day)
Finally
One more example:
If-(
 | Receive X10 House Code 'A' Unit Code '2' Command '3 - on'
 | Or-(
 |   | Status '04.BF.8D.1' is On
 |   | And From Sunset
 |   |     For 3 hours
 |   | And(
 |   |   |   | Program 'Office Hours' is True
 |   |   |   | And Program 'Office Hours' is False
 |   |   | Or Control '07.EB.6D.1' is Fast On
 |   |   | Or From Sunset
 |   |   |     For 4 hours
If (
   Or (
       And From Sunset
           For 3 hours
       And(
           Or From Sunset
               For 4 hours
Mark,
Thank you. We'll revisit for the next release.
Regards,
First example:
   Status AC is Off
   And (
       Time is 5:00PM
       Or Time is 4:00PM
       And Temp > 90
   Set AC on
Another example:
   From 9:00:00AM
   Or On Sat
   From 10:00:00AM
Finally
One more example:
If-(
 | Or-(
 |   | And From Sunset
 |   |     For 3 hours
 |   | And(
 |   |   | Or From Sunset
 |   |   |     For 4 hours
If (
   Or (
       And From Sunset
           For 3 hours
       And(
           Or From Sunset
               For 4 hours
