Program not working
so.. I can't figure out why this program is not working.. turned the fan on manually.  temperature is 71 degrees..  fan not shutting off...
<?xml version="1.0" ?><triggers><d2d><trigger><id>216</id><name>Living Room Fan Off</name><parent>207</parent><if><and /><device><status /><node>25 18 7A 1</node><op><=</op><control>ST</control><action>148</action></device><and /><device><status /><node>3F 4D 92 2</node><op>!=</op><control>ST</control><action>0</action></device></if><then><device><node>3F 4D 92 2</node><control>DON</control><action>0</action></device><wait><minutes>15</minutes></wait></then><else></else><comment></comment></trigger></d2d></triggers>
