Automatic.com
themlruts
I've looked at it but don't own it.  Seems to be rated fairly highly and has IFTTT channel.
What are your plans for it?
Jon...
It stays plugged in full time. I track all of my trips, and flag those that are 'business' so I can pull a mileage report as needed.
I also use an app called "Dash Command" that allows me to get into the guts of the OBD and see what's going on.
Automatic is 'ok'. It doesn't give you everything you want. No instantaneous mpg is one missing item. For what it does (as per the web page) it functions fine.
Was there something you wanted it to do? Or want to know if it did?
You can use it as a location point as you would a phone and program events when the car enters into a specified area.
If you look over the connect car channels on IFTTT you'll see a number of options.. Dash, Zubie, Mojio
Jon...
Edited by jerlands
