Keypadlinc and scene not working right
Jay M
I have a 6-button keypadlinc on the wall, and button C used to be for a scene call "movie" that would turn off any lights in or near the living room.  I never used that button, so I re-purposed it.  To activate that scene, I always use an IR remote.
I created a new scene called "Away".  That scene turns off any non-essential lights when I'm away.  I never like to leave the house totally dark.
When I assigned the Keypadlink button C to the Away scene, it still triggers the "Movie" scene.
What could cause this situation?
thanks,
~Jay
Did you manually link the button?  Try restore device and see if that doesn't remove other links.
Jon...
Did you alter the Movie scene or did you create a new Away scene? If the latter, is the IR command still pointing to the Movie scene?
Thanks guys!  You helped me figure it out.
For some reason, I had a program that said:
if button is pressed
Or IR is pressed,
turn movie scene On.
I just removed the button press line.  I haven't tested it yet, but I'll be that was the problem.
Do you need to program for IR to work, or can IR directly control a scene?
I use the IR built into the ISY.
thanks,
~Jay
Thanks Michel.
What would you suggest I do when I do want both a button and ir control of a device?
Here's an example...
I have a button on the IR remote to turn on a fountain in the back yard.
I also have a button on a keypadlink that turns on and off the fountain.
How can I make sure the button is illuminated when I use an IR command?
~Jay
      38.2k
      381.1k
