Keypadlinc mutally exclusive button mode limits?
Hi,
Sorry for being a pain in the butt here..
Just changed my wreck-room from X10 to 6 insteon zones (2476 dimmers)
There is a KPL that has its buttons set to control individual SWL's and that works fine.
I have a second KPL that controls the scenes (7 scenes and the main does All ON/All Off) Everything in the Scene controls works fine except the Mutually Exclusive buttons feature. I have all the scene buttons (B to H) set to be mutally Exclusive. Buttons B to E work fine, but F,G,H cause ALL the buttons to light when pressed. I've reset the buttons several times with no luck.
What might I be doing wrong?
thanks
Hello again,
I suspect you are using the brand new KPLs and an older ISY firmware. Please upgrade to 2.6.13 if you have not done so.
Hi,
thanks
Ok I'm running 2.6.5 so I attempted to "upgrade" to 2.6.13
-backed up ISY
-Instructions say "Step 1 - This step is necessary if and only if you are upgrading from any release except 2.6.11 and above" I'm only at 2.6.5 so I must do this, but file to "Upgrade to" is 2.6.0... sounds like a downgrade to me but I do so anyway. That goes Ok, upon reopening the console I have no devices, but I soldier on... I now do the update to 2.6.13.. then I then get an error that says something about file length or buffer length, I can't remember..
-so I re-upgrade to 2.6.5 and that goes Ok. So I try to upgrade from there to 2.6.13 and I get error "Socket Open Failed java.Lang.NullPointerException" followed by error "upgrade Failed: ISY Refused program Update"
-So now I try to go back to 2.6.0 again and get the same error as above.
So I don't understand something about the upgrade procedure. Am I right that I have to downgrade to 2.6.0 first?
RF_Burns,
I do apologize for the inconvenience. I suppose you have ISY-26.
1. Step 1 is to install a reduced function code (thus no devices) so that you can install 2.6.13
2. The reason for invalid length issues is usually the firewall
If you don't mind, please do the following:
1. Checkout our firewall section for solutions to most firewall issues http://forum.universal-devices.com/viewforum.php?f=3
2. Reboot your ISY and then Reinstall 2.6.0
3. Install 2.6.13
Please do keep me posted.
-backed up ISY
Michel,
I found a posting on AVG 8, I am using the free edition here at home so I disabled it. Then I got to 2.6.0 no problems but still had an error going to 2.6.13.. I was using FireFox so I tried again using Windoze Explorer and all went well.
My issues are fixed with KPL mutually exclusive settings now.
:D
Hello RF_Burns,
Thanks so very much for the update. I am very surprised that you had issues with Firefox since that's what I personally use 99% of the time. Are you sure you have the latest Java plugin for your FF?
Michel,
:D
