List of Spokens
I'd like to be able to print a lost of spokens and the device/scenes/progams each controls other than page by page printouts.
If its lost how do you know what the words are?!?! LOL
Good point. If I had a list, then it wouldn't be lost.
On Topic: Are you asking for all of the spoken phrases the skill will accept?
No. The devices I added to the portal for Echo control.
I'm sure it can be retrieved from the API - its just not documented... I'll take a peek this evening.
URL is:
https://my.isy.io/api/voice/spoken/nodes?uuid=<UUID>
This returns JSON which includes the node address, name (on ISY) and an array of the spoken elements.
The UUID is URL encoded...  so if your ISYs UUID is 00:11:22:33:44:55 the <UUID> parameter should be 00%3A11%3A22%3A33%3A44%3A55 (simply replace each : with %3A)
You'll need to send basic auth using your portal credentials.
Michael.
Michael,
Thanks a lot. More info than expected makes the command even more useful. BTW, I didn't need to replace : with %3A.
Thanks again B)
If you are simply pasting the URL into a browser - the replacement would be done automatically...  Some products might need the replacement though...
Either way - glad it was helpful!
  • 3 months later...
Hi Michael,
Has this URL changed?  Should it work from any browser?  I tried it with my UUID, was prompted for credentials, but then Chrome said "server error".
Also tried embedding credentials, i.e. https://myusername:mypassword@my.isy.io/api/voice/spoken/nodes?uuid=myuuid, with the same "server error" result.  Am I doing something wrong?
Thanks in advance for any suggestions.
-Barry
Looks like the url now also needs a 'domain' parameter. You can get your domain value from an api call to:
The _id value is what you need to add to the original url as &domain=......
It should look like this:
https://my.isy.io/api/voice/spoken/nodes?uuid=<UUID>&domain=<DOMAIN>
Unfortunately, the API is not formerly documented - and subject to change. I discover this by analyzing chrome in developer mode...
Michael.
Edited by MWareman
