Simple programming if statement
I'm using a switch to turn on several switches. Here's the problem, in the if statement, it shows percent on level for my trigger. How do I control it if I don't care what level on %, just anytime the button is turned on?
In the admin console > Help > About what does it show for firmware and UI version?
Some versions have both Status and Status(Old) and you'd need use Status.
Jon...
I know it's the latest firmware but I will check when I'm home. If my memory serves me correctly, there was responding, and 1-100%. There wasn't status but I'll check again.
can you post a copy of your program
Use "switched" instead of "status"
If "status" is actually wanted then use "Not Off" or "> 0"
If one SwitchLinc is used to control light2 with Status,
and then light2  is turned off, but then wanted back on from the first SwitchLinc, "status" will not operate the second switch via a program.
"Switched" will trigger a program every time the switch paddle is operated.
"Status" will trigger a program only when the switch turns on the light.
Note: Earlier than v5.x ISY versions use
Control switchlinc is switched 'On'
while v5.+ uses
The 'control' word may be disappearing.
As Larry pointed out.. for dimmers you'd use "Not Off" where as relays have the option for On
Jon...
