Wait statements in program
I am trying to create a single program that would dim lights to 50% and brighten back to 100% over a 2 day period.  Is there a cleaner method than using the wait (I would prefer times instead of hours and minutes) command.  My program is below.  As an aside it did not work, but I had on Sat, and Fri in the "if" statement.
Moshe
Bathrooms - [iD 0022][Parent 0006]
        On Fri
        From     6:30:00PM
        To      11:00:00PM (next day)
        Set Scene 'Bathrooms' On
        Wait  4 hours and 30 minutes
        In Scene 'Bathrooms' Set 'Bathrooms / Downstairs Bathroom' 50% (On Level)
        In Scene 'Bathrooms' Set 'Bathrooms / Master Bathroom' 50% (On Level)
        Wait  8 hours and 30 minutes
        Wait  2 hours and 30 minutes
        Wait  1 hour and 30 minutes
        Wait  3 hours
        Set Scene 'Bathrooms' Off
Your program sets devices in a scene to a particular level and turns the scene on, then, after waiting, sets the same devices in the same scene to the same levels. The scene will execute on Fri at 6:00PM and again at Sat at 11:00PM. There is no statement that turns the devices back to 100%.
What specifically are you trying to accomplish (e.g,, between sundown and sunrise, shabbos)?
Wait statements in a single program, or separate programs run at discrete times are the two options that come to my mind.
I understand that you want a set of lights to "dim" (turn on to) 50%, then gradually (2 days?!) increase to 100%.  Your program turns the lights on to whatever level they are currently set, then sets the responder level to 50% then turns the scene on then sets the responder level to 50% (again?!) then turns the scene on then sets the responder level to 50% (again?!) then turns the scene on.  I see nothing that increases brightness levels to any value other than 50%.
Thanks stusviews and oberkc -
This is what I am trying to do.  I would like the bathroom lights to turn on at 6:00 PM on Fri, at 100% brightness  wait a few hours and dim down to 50% brightness , again wait so many hours and brighten back to 100% and so on.  I would like the lights to react immediately after the wait time. (I am trying to configure for Shabbos and Yom Tov ultimately.)
Moshe
Devices/scenes do not automatically turn on after a wait state. You have to issue a command to turn then on.
Set 'scene_name' on
Wait
In scene 'scene_name' set 'device_name'  50% (On Level)
Set 'scene_name' on
Wait
In scene 'scene_name' set 'device_name'  100% (On Level)
Set 'scene_name' on
repeat as needed. Glick B)
That is what I did but it did not work.  I am not sure what I am doing wrong.
Moshe
Moshe
Post your revised program.
Jon...
Hi
I like to use more than 1 program,
If 6 pm
then set xxx to 100 %
Program 2
If 8pm
Then set xxx to 50 %
Ect.
Actually, a multi-program strategy can eliminate the need to repeat the same statements:
Main Program
        whenever
        Run Program 'dim' (Then)
        Wait
        Run Program 'bright' (Then)
        Wait
Program Dim
              - No conditions -
             Set 'scene_name' on
Program Bright
          - No conditions -
             Set 'scene_name' on
Are you sure that is what you did?  If you judged the outcome after 4 hours and 30 minutes, you might reach that conclusion, but you might also be wrong.  Your program, as written, would not have any affect on actual lighting levels until 13 hours (4h30m + 8h30m).  Your program will NEVER brighten back to 100% (all your statements set the levels to 50%), and I am curious which of the statements you expected to do so.
When you say a "few" hours, do you not have a specific time frame in mind?
My temptation would be to create a couple of scenes: Bathroom50% and Bathroom100% with obvious responder level settings.  Create a program:
        On Fri
        From     6:30:00PM
        Set scene bathroom100% to ON
        Wait a few hours
        Set scene bathroom50% to ON
        Wait so many hours
        and so on
else
        nothing
Edited by oberkc
All -
Thanks for the help.  It seems I need to make a couple of scenes to make this work they I would like.
oberkc -
The statement that should bring the lights back to 100%  is "  Set Scene 'Bathrooms' On" since I could not adjust the scene "bathrooms" to 50%, I added the statements. "In Scene 'Bathrooms' Set 'Bathrooms / Downstairs Bathroom' 50% (On Level)
        In Scene 'Bathrooms' Set 'Bathrooms / Master Bathroom' 50% (On Level)"
I thought the last two statement would bring  brightness to 50%.
Concerning the wait statements:  The first wait statement of 4h30m should fire off first, dim to 50% and then after 8h30m brighten to 100%.  I am not sure why it would wait a total of 13 hours (you are correct it did wait 13 hours)
Moshe
I think there is some confusion about the purpose of the "in scene set xxx/yyyy to 50%".  The confusion is, based on my reading of this forum, pretty common.
Let's take your first "set scene" statement, that runs after 4h30m.  That statement:
will do nothing more than change the responder ON level of a device "Downstairs Bathroom" to 50% when responding to a controller device (or scene) called "Bathrooms".  It will not actually cause the device to immediately change to 50%.  Once changed, the next time the device (it could also be an ISY scene name) "Bathrooms" is commanded to be ON, the responder device "Donwstairs Bathroom" will turn to 50% level.
Remember, a scene can have many controllers and many responders, with each responder having a specific ON level (anywhere from 0 - 100%) defined for each controller.  If, for example, you have a scene called "Bathroom" that includes a device called "downstairs bathroom" where the responder level for that device defined at 50%, turning ON the scene will cause the "downstairs bathroom" device to turn to 50% (the defined ON level).  Turning ANY scene ON will cause all included device to go to the defined ON levels, unique for each controller in the scene.
Back to your first command after the 4:30 wait...all it did was adjust the level to which one device would turn ON if/when that scene was ever commanded to turn on (which did not happen until 8h30m after that.
No.  That statement would only cause the light to turn to the defined ON level, now 50%.
While my initial reaction would be to think this might be the most convenient way, it is certainly not the only way.  In fact, you could use your approach, but it would require several more program lines and have, in my estimation, little benefit.
Edited by oberkc
1. Setting a scene to an On-level does not turn the scene on. That has to be done manually, via the ISY interface or from a program, Setting the scene to an On-level only sets the level for the next time the scene is turned on.
2. When I create a program with 'waits,' it's not the wait I'm testing, it's the other statements. So, I usually set the wait to a few seconds during testing.
3. If the program has a start and/or end time, I set the time to begin in a minute or two and adjust the end time, if any, appropriately.
oberkc / stusviews -
Thanks so much for pointing in the right direction.  I did not realize the in-scene statement would not immediately initiate the command to go to 50%.
Thanks again
Moshe
I think you might be better served by having 2 scenes for each of the 2 lighting situations (a full bright scene and a dimmed scene).  Your program would then read more or less like oberkc's in post 10.
apostolakisl -
I agree oberkc's post 10 seems to make the most sense.
Moshe
The only other thought is if the scene is not complex (only one load device), you might consider something like
Scene on
wait some time
set 'the load switch'  50%
wait some time
set 'the load switch' 100%
wait some time
set scene off
