Announcing 'Home Alarm' - a Android app for arming and disarm your Elk M1
Version 1.0 of 'Home Alarm' is now available on the Google Play store at https://play.google.com/store/apps/details?id=com.wareman.ha.
Requires:
* Universal Devices ISY (https://www.universal-devices.com/)
* Elk M1 Alarm system (http://www.elkproducts.com/)
* ISY-ELK integration module installed on your ISY
For remote access, either:
* ISY Portal (https://my.isy.io) (currently only supports single ISY in a Portal account)
or
* SSL certificate installed on your ISY (trusted preferred - but self-signed supported)
(ISY Portal is highly recommended - it's much faster than direct SSL, and comes with added benefits including Alexa and IFTTT integration)
* Supports remembering your home WiFi network(s). Simply click 'Profile : Remember this network' when on the same LAN as your ISY and it will auto-switch to a speedy local connection (you will need to do this for each AP)
* Supports two profiles - in case you have two systems. Swipe-left on the status display to setup after the first profile is configured. Network awareness is independent for the two profiles
1.0.1 (build 112) has just been promoted to production.
New:
Supports Android 4.0+ (previously 4.1+)
Adjustable font size (in settings) in case text on buttons is too small (or big)
Actually exits now (if enabled) on disarm
New long/short press options:
  Allows a long press to function even if short is also allowed
  New button activation option: 'Long if no PIN'
    This allows short (or long) if there is a PIN required - but require a long press where no PIN is required (to prevent accidental activation)
  • 10 months later...
1.0.5 now available.
New features:
Screen rotation
Color changing LCD
Startup performance tweaks
      37k
      371.4k
