ISY 994I PRO & Java 8 Update 77 & Dashboard V4.0.5
I have a Universal Devices 994I PRO,
   Lights on front are Power-Blue, Tx-Blue, Rx-Blue, Memory-off, Error-Red
   Lights on back are both green
I have updated to Windows 10
I have updated to JAVA 8 Update 77 (build 1.8.0_77-b03)
I think it is correct to say I am using Dashboard V4.0.5
My ISY 994I is wired to a router, my laptop is connected to the router wirelessly and the router communicates to the internet.  After the update to JAVA 8 and upon doubling clicking either my ISY994 Administrator or Dashboard shortcuts I receive the following error: "Application Blocked by Java Security".
I tried going back to an old JAVA version and got missing JAVA file error, so I uninstalled and returned to JAVA 8.
I tried updating the exception list in JAVA 8 using the JAVA console, but I really don't know what to enter there.
Prior to these updates I could update the 2413S Power-Line Modem (PLM), now I cannot.  I did not test the connection after the Windows 10 update and prior to the JAVA 8 update.
I have complete system backups before and after the Windows 10 update.
I believe the JAVA 8 update has stopped my connection all together.
Before I use my backups can you provide any help in pointing me in the right direction to continue under Windows 10 and JAVA 8?
I have a notebook running windows10 and latest java update (8.77) without issue.
It sounds like ISY is hung up since both RX and TX are illuminated (typically only power light is illuminated and RX and TX blink when receiving and transmitting.)
You might try a hard reboot by removing power from ISY, wait 30 sec then plug back in.  Observe lights during boot and reference Wiki.
Jon...
Jon...
Are you using ISY994I PRO or a newer device?
994i Pro which is the latest version.  The admin console is the interface to ISY and is dependent upon Java but ISY itself isn't.
Jon...
I had the the same issue after updating to 77. Rebooting the PC resolved it for me.
Once you get back in... your Firmware version and UI version (Help > About in UI) should be the same and also it's probably advisable to upgrade to the latest official release 4.3.26
Jon...
