ISY Portal slower than MobileLinc Connect
Is anybody else having issues with how slow the ISY portal seems to take to update MobileLinc compared to how quickly MobileLinc Connect would update?
I used to be able to open MobileLinc and it would immediately start to update my device status from MobileLinc Connect. Now, when I open MobileLinc connected to my.isy.io, it opens with all greyed out items and then 10-15 seconds later, they start to populate status. This just seems like an extremely long time to have to wait to be able to turn something on/off.
Are others having the same delay issues?
Hi mdonato,
The issue is that we had to put a LOT Of hooks in ISY Portal to support MobiLinc especially with regards to subscriptions. So, a simple process of subscription would require: checking the base URL, fixing it, checking the profile for My Preferred ISY, attaching it to the session, and a lot of other things that would have automatically worked if MobiLinc supported a path in the URL + fixed the headers. In short, I would say that ISY Portal is "emulating" MobiLinc Connect. You can test this by using ISY Web Access which is almost instantaneous.
