Help with door left open program
I think my previous thread was deleted but I have these two programs running to let me know if I left my door open and it works fine.
Garage Man Door left open  - [iD 0054][Parent 0050]
        Status  'Garage Small Door-Opened' is On
    And Status  'Garage Small Door-Opened' is not Off
        Wait  2 minutes
        Send Notification to 'email' content 'Garage man door left open'
        Send Notification to 'Pushover' content 'Garage man door left open'
        Enable Program 'Garage Man Door repeat '
        Run Program 'Garage Man Door repeat ' (Then Path)
        Disable Program 'Garage Man Door repeat '
Garage Man Door repeat  - [iD 0058][Parent 0050]
        Repeat Every  30 seconds
I want to use this program to disable the above programs for 20 minutes then re enable them and this does the trick.
Disable Garage doors left open - [iD 005C][Parent 005B]
        Disable Program 'Garage Man Door left open '
        Disable Program 'Overhead Garage door left open'
        Disable Program 'Overhead Garage Door repeat'
        Wait  20 minutes
        Enable Program 'Overhead Garage Door repeat'
        Enable Program 'Overhead Garage door left open'
        Enable Program 'Garage Man Door left open '
The problem is after the 20 minutes are up, it re enables the "garage man door left open" program but if the door was still open at the time, it doesn't notify me again.  How do I make it check if the door is open or not?
Have you tried putting a "RunIf garage man door left open' below the enable?
If you say "run if" does that run the whole program or just the "if" section of the program?
 You should be able to simplify the first two programs into one simpler one.
Then add the Run Program(If) line suggested by KeviNH above to restart the disabled sequence again.
        Status  'Garage Small Door-Opened' is On   <---off will run Else and stop Then
    And Status  'Garage Small Door-Opened' is not Off    <---not required for status
       Wait  1 minutes 30 seconds
       Repeat for 9999 times
           Wait 30 seconds
It runs the If and depending on the outcome runs the Then or the Else section of code.
So I am going to kind of hijack this thread some. Larryllix you taught me before how to run two programs, so I have been and have told others here like Blackbird to do it to help him. So are you saying for my programs below I could cut it down to one program now with those changes?
First Program:
Side Gate Left (Dog Run)
Elk Zone 'Side Gate (Dog)' is Violated
And Elk Zone 'Side Gate (Dog)' is not Normal
And Elk Area 'HOUSE' 'Armed State' is Disarmed
Send Notification to 'Pushover' content 'Side Gate Notification'
Enable Program 'Side Gate Left (Dog Run) [speak]'
Run Program 'Side Gate Left (Dog Run) [speak]' (Then Path)
Disable Program 'Side Gate Left (Dog Run) [speak]'
Second Program:
Repeat Every 10 seconds
Set Elk Speak Word 'Front'
Set Elk Speak Word 'Side'
Set Elk Speak Word 'Gate'
Set Elk Speak Word 'Open'
And Elk Area 'HOUSE' 'Armed State' is not Disarmed
Wait 10 seconds
<crazy stuff snipped> :)
    Wait 10 seconds
In this case I believe there is no reason not to combine the programs.
Usually two programs are required when there are conditions we don't want to stop the programs line, no matter what.
If trigger stimuli, Then run program2
Program2: (disabled)  If 'another condition we want to test but not ever stop execution' Then 'don't stop code lines'
This is common with time frames where we don't want the end time to stop Then in the middle.
Anther case is where we want to check for a specific sequence of events. We don't want the program2 running unless the dryer is started first.
If  Dryer is On, Then Wait 4 minutes, Enable Program2
Program2:(disabled)
If Dryer is Off, Then Notify Wife 'Get clothes out now!',  DIsable self again
So this should work
   Repeat for 9999 times           <---double repeat corrected
     Wait 10 seconds
           Wait 30 seconds
Seems to work good.  Thanks
