GE Jasco outlet 45605 won't add
I am migrating my z-wave network from a Vera 3 to my ISY.  I can't seem to add a GE Jasco 45605 outlet to the network.  It removed just fine, several times in fact, but when I try to add it the ISY waits forever no matter how many times I push the button on the outlet.  I never had a problem getting it to work with the Vera.
I'm less than 10 feet away from the ISY.  Also, it's in a 2 gang portable junction box (my test rig) next to an Intermatic z-wave outlet module.  That one removed and added on the first try, and turns on and off instantly, so I doubt I'm having any transmission problems.
I remember reading something Michel wrote about some of the GE Jasco devices acting this way.  Are there any tricks to getting them to enroll?  Are there any diagnostics I can send you to assist in diagnosing the problem?
-Tom
Hello Tom.
I just wanted to say bravo for coming over to isy. You will not regret it.
I wish I had some info about Jasco devices, but I use all Enerwave devices. No worries though. I guarantee someone will be along soon with some assistance for you. Hang in there. [emoji106]
GT
I have a ge outlet and had no issues getting it to show up.
Did you try to reboot the ISY?
I find quite a few things work only after a reboot, but then again I'm running beta software so I can't complain.
Since first posting I have rebooted the ISY and factor reset the Z-Wave dongle several times.  The behavior of the Intermatic outlet is still the same.  The GE outlet can be excluded, and when I attempt to include it by pushing the button on the outlet it now says it is retrieving info 2, then the dialog goes away, but no new device appears in the device tree.  Progress?  Maybe, but not enough.
-Tom
Are you on 5.XX alpha?  Has anyone been able to get one to work on 4.4.6?
-Tom
Yes 5.0.2.
I didn't have the the outlet before I was on 5.0.2 so I cant say if it works on the 4.x.x firmware.
Since my last post, I have included the outlet on the vera, operated, and excluded it.  I have included it on a GE 45600 remote, operated it, and excluded it.  It still won't allow itself to be included on the ISY, though it still will allow itself to be excluded.
Michel, it appears there is no factory reset.  The manual states that exclusion resets the device, and it's the only reset there is.
I'm still offering to collect any logging information, if that can be done.  I could also send you this device so you can look at it.  Does no one have this working with 4.4.6?  Maybe I'll have to wait until v5 is released.
I might try including it on one of the controllers above and transferring the network to ISY as secondary, but long-term I want the ISY to be primary.  Or maybe I'll try another outlet.  I bought a lot of them when Radio Shack was clearing them out.  They were cheap, and support beaming.  The Intermatics, though even cheaper, do not.
-Tom
Michel:
Yes to both.  I'll try another one next time I go up in my attic, where they're stored.  That might be a few weeks from now.  I'm thinking it could just be a bad unit.
I noticed it acted a little weird when I included it with the Vera last time, too.  Vera has a multi-step wizard that is supposed to move automatically to the next step once it is finished including a device, and it didn't do that for the 45605.  I hit cancel, and the device showed up in the list anyway.
In addition to the Intermatic outlet, I was able to add a GE Jasco 45604 outdoor outlet to the ISY no problem.
-Tom
  • 3 weeks later...
Good news.  I got a new, unused one out of my attic, and it worked flawlessly.
I wish I knew what went wrong with the other one.  I'm glad I hadn't installed it in my wall.  I got these for $10 when Radio Shack was closing them out. They beam, so I planned on using them to help my ISY reach my lock.  I hope this was a one-off failure.
-Tom
