ISY to Global Cache to turn on tv.
Trying to follow the steps to setup a resource to turn the tv ON. i have ilearned it, and send IR in the tool turns on the tv. I copied it to the body, added /r/n to the end hit update and save.
sendir,1:1,2,37993,1,1,171,170,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,1782,171,170,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,1781/r/n
Changed to tcp,ip port 4998
timeout 500ms
mode C Escaped
set up new program , assigned resource to then (The drop down arrow next to resource it is blank.)
tried to run then but no activity on the IR lights on the tv.
Am I missing something. Is it a ilearn repeat or connector or module setting?
and my test button is grayed out.
Edited by chachdog
When you test the resource in the network module, what response do you get?
test is grayed out
test is grayed out
Click on the resource in question, the test button should become available.
Is it possible to build the sendir commands manually without the ilearn app? can i look on the internet for discreet codes and modify them or is it different format?
There are sites that post IR codes so you can just copy and paste them. I got all my Onkyo receiver commands that way. Search for 'discrete IR codes' online.
 format looks different. how do you convert it?
Device Code: 7.7 Function: 67DTV
0000 006D 0000 0022 00AC 00AC 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0689
If you find hex values like these, use the GC iConvert app to translate them into usable strings.
At the end of the ir sting it should be \n\r not /n/r. The line feed is not being sent just the string /n/r
  • 1 month later...
Hi,
I've been looking around for instructions on setting up the ISY so I can send commands to the Global Cache iTach WF2IR unit I just purchased.
I want to send a Power On/Off (Piwer Toggle command) to my Air Conditioner.
I believe I have the codes leaned via iLearn that comes with the iYTach. Plus I think I also have the CCF codes that I downloaded. I have another device that works talking to the iTach.
I just am looking for instructions on how to get the ISY to talk to the iTach.
Can you point me to the place wherer you got your instructions.
I am assuming I need the Network Module installed to make this work?
Or is having the ISY Helper good enough to use as well?
Thank you!
Rob
Edited by rlanza1054
