WebControl - WC8: Data poll error - Invalid URI: The Authority/Host could not be parsed
Hello io_guy,
I have been trying out NodeLink and have been able to add dsc alarm to it and isy successfully. I am having issues with the webcontrol8 boards. I believe they have changed the gui and I am getting this error WC8: Data poll error - Invalid URI: The Authority/Host could not be parsed.
Reading thru the forum I found a post by Xathros where he had attached his xml file from his wc8 which stated his fw was v03.02.13
Mine is v03.02.18b5
I have attached mine for reference.
Tim
wc8.txt
Tim,
Is it the same /api/status.xml url you use to get this info?
I dump your file directly into NodeLink and it parses fine.  What address do you have configured in the NodeLink page, this seems more like an http issue.
Edited by io_guy
Yes, I copied that info right from one of my wc8's from my browser..
I am using "192.168.0.169" as the address. admin / admin as user/pass.
Does the "NetBIOS name" in wc8 matter?
Do you need "web login enabled"?
NetBIOS doesn't matter. If you can get to it with Internet Explorer, then NodeLink should work (for login).
Any chance you can expose it externally to allow me to connect?
Is there a setting by chance in NodeLink that will allow you to access? Or do I need to configure in my router to expose it?
Big thanks to io_guy once again. It turns out that in the "Device" tab when I was adding another device I was changing the "Node Profile Number" increasing it by 1. Once I left the profile number the same the Uri error would occur after adding a device until NodeLink was restarted. Then all was well.
Thanks again,
Tim
