Problem with light % at different hours
These programs do not modify scenes.
Insteon scenes are between devices and ISY has management tools to modify them.
Scenes in your case can be used to group devices into looking like one device to ISY but you have no controllers in your scenes to operate outside of ISY.
OK I gave the program below a shot and it works, but like you said you get that 100% flash before the program runs, I had to turn up my ramp rate all the way to 4sec which is not a big deal at night but during the day the wife will kill me if she has to wait 4sec to see:
Night Lights - [iD 000E][Parent 000D]
        From    10:30:00PM
        To       6:00:00AM (next day)
    And Control 'MasterBath Toilet Light' is switched On
        Set 'MasterBath Toilet Light' 40%
I tried the reverse as well setting the local on at 20% and have the program run at 100% during the day but I still get the dim-bright flash. So basically I need to add a controller to make this work, correct? Can I use a KPL button, and how would I do that?
Edited by Ajax
In the admin console, access the device's page and set your brightness level to about 30% and the ramp rate to 2.0 seconds.
