DSC - DSC Program question
I have some programs set up that run based on the disarming user, and they work successfully.
I am trying to add a new one today, however in the program conditions I can't seem to select disarming user any longer, is this a known issue with 5.0.4 and 0.5.5 ?
This is an example of the original program which works, I can't seem to find the "Disarming User" option any longer in the program conditions - Thoughts?
Martin Disarm - [iD 0040][Parent 003E]
        'Node Servers / DSC Alarm / Partition 1' Status is Disarmed
    And 'Node Servers / DSC Alarm / DSC Alarm' Disarming User is 3
        Resource 'DSC_MartinDisarm'
I think I see it on mine using 5.0.4 and the latest nodelink.  On the IF statement, I can choose STATUS and then 'DSC Alarm / DSC Alarm' and then 'Disarming User' and then 'IS' and then a USER NUMBER.
Working fine here.
It's under the main node, not the partition node.
I realize its under the main node, however I don't see the main node in the drop down of options - That's my problem.
Going to clear my java cache, and reboot the ISY and see if it helps.
But I do see the main node in my device list.
https://dl.dropboxusercontent.com/u/42536394/Screen%20Shot%202016-07-02%20at%209.28.37%20AM.png
https://dl.dropboxusercontent.com/u/42536394/Screen%20Shot%202016-07-02%20at%209.28.49%20AM.png
https://dl.dropboxusercontent.com/u/42536394/Screen%20Shot%202016-07-02%20at%209.29.03%20AM.png
None of that seemed to work, I did re-upload the nodesetup.exe file and rebooted, and that fixed my issue.
I must have missed an update to that file at one point possibly.
Thanks folks.
