NedB Posted July 19, 2016 Posted July 19, 2016 So I've got a new ISY 994i with the Elk module. In ISY I can see the alarm settings, and the thermostat I have connected to the Elk alarm. For some reason, I expected (with version 2) to be able to see those devices in the ISY portal and expose those to my Echoes, just like any of the Insteon switches I have. That is not the case. So only thermostats connected to the ISY can be controlled by Echo? Or is this something coming in the future? Quote
Scottmichaelj Posted July 20, 2016 Posted July 20, 2016 Not sure I understand what your asking. If you have the Elk module then all you need to do is setup a program or whatever you want and then map it to the echo via the ISY portal. Make sense? Quote
MWareman Posted July 20, 2016 Posted July 20, 2016 (edited) I think the issue is that thermostats native to Elk are not expressed as native nodes on ISY, or thru it's API. To manipulate them, you need to make API calls via the Elk endpoints - not device endpoints. Only device/scene/program endpoints are available in the Echo integration. IMO, this is not that bad. You can create programs that implement the functionality you need and then access the program thru the portal and Echo. I really don't want to be able to disarm my Elk via my Echo! Edited July 20, 2016 by MWareman Quote
G W Posted July 20, 2016 Posted July 20, 2016 On 7/20/2016 at 11:41 AM, MWareman said: I really don't want to be able to disarm my Elk via my Echo! Unless the Echo has 100% voice recognition. I could see arming it or a panic alarm. Best regards, Gary Funk Quote
Michel Kohanim Posted July 20, 2016 Posted July 20, 2016 Hello everyone, ELK attached thermostats do NOT show up as thermostats in /rest/nodes. And, therefore, the portal cannot do anything with them. With kind regards, Michel Quote
