Ecobee - Linking Ecobee3
Request New 3rd Party Pin doesn't work.  Running NodeLink as a docker.  Any tips?
When you say that it doesn't work, do you not see a new code show up in the log?  Clicking the button doesn't have any directly visible effect, only new entries in the log with the code to enter on the Ecobee website.
Check and see if you're using my new Dockerfile.  It needs to install mono-complete.
https://hub.docker.com/r/jcreynolds/nodelink/~/dockerfile/
Thanks, this makes more sense.  Does it take a bit to kick in?  I've added the pin to ecobee and states nodelink is in myapps.  However the page isn't updating with data.
2016-07-19 23:08:29 - ISY NodeLink Server v0.5.7 started
2016-07-19 23:08:29 - ISY resolved to 192.168.1.200
2016-07-19 23:08:29 - Web config server started (http://172.17.0.10:8090)
2016-07-19 23:08:29 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2016-07-19 23:08:31 - Ecobee: New 3rd party app code is mm95 [ecobee1]
2016-07-19 23:08:31 - Ecobee: Error refreshing tokens - if this continues try setting a new app pin [ecobee1]
2016-07-19 23:11:32 - Ecobee: Error refreshing tokens - if this continues try setting a new app pin [ecobee1]
2016-07-19 23:14:33 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1/report/status/GV2/-1/25)
2016-07-19 23:15:03 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1/report/status/GV2/-1/25)
2016-07-19 23:15:33 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1/report/status/GV2/-1/25)
Is it supposed to create a new app code every time nodelink is restarted?
Edited by JayC
Just gotta stay patient  :-P.  However, does a new pin get generated on restart?  I saw it once but it may have been a coincidence as I may have generated a pin and restarted.
Thermostat Variables
Name	Home
HeartBeat	-1
HVAC Mode	Cool
HVAC State	Cooling
Schedule Mode	Schedule
Schedule Type	Home
Fan Min On Time	0
Fan State	On
Indoor Temperature	78.1
Indoor Humidity	52
Cool Setpoint	78
Heat Setpoint	69
Weather
Temperature	71.7
Humidity	93
POP	11
High Temp	89.4
Low Temp	76.1
Sensors
S1 Temp (Bedroom)	78.3
S1 Occupancy (Bedroom)	1
S2 Temp (Home)	77.9
S2 Occupancy (Home)	0
No, you should only need to generate the pin once. After that it saves the oauth keys and should be fine
I can see the data in ISY, I also can change the setpoint from ISY and see it update on the Ecobee.  However I am seeing the following errors in the logger:  Also what is the Install ISY Nodes button supposed to do?  By default my nodelink will add the the thermostat data into the isy.  The check boxes when checked will automatically add the weather and sensors.
2016-07-20 08:32:46 - ISY NodeLink Server v0.5.7 started
2016-07-20 08:32:46 - ISY resolved to 192.168.1.200
2016-07-20 08:32:46 - Web config server started (http://172.17.0.10:8090)
2016-07-20 08:35:00 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2016-07-20 08:35:35 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1_sen1/report/status/ST/78.6/14)
2016-07-20 08:36:05 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1_sen1/report/status/ST/78.7/14)
2016-07-20 08:36:35 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1_sen1/report/status/ST/78.7/14)
2016-07-20 08:37:06 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1_sen1/report/status/ST/78.7/14)
2016-07-20 08:37:36 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1_sen1/report/status/ST/78.7/14)
2016-07-20 08:38:06 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1_sen1/report/status/ST/78.7/14)
2016-07-20 08:38:36 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_ecobee1_sen1/report/status/ST/78.7/14)
Edited by JayC
The readdone2 was a failure to add the new node in the ISY, hence the 404s.
Keep hitting the install nodes button until the nOl001_ecobee1_sen1 node shows up in the ISY.
Readdone2 is a mono bug.
