Motion Sensor stops sensing
I have a 2420M motion sensor, which for some reason the sensor stops working after a day or so. I changed the battery, and moved it closer to an access point to test, same results. If I remove the battery, and leave it out for a few minutes, then reinstall it, the sensor works for some time...
Any ideas as to why?
Burak
Burak
What is the voltage on the battery you remove?
Burak
Don't really know, twice I replaced with new battery... I'll get a voltmeter and check...
That said, the old way of sticking your tongue on the 9 volt battery technique indicated battery is full :D
Hi Burak,
I think this is related to your post where the PLM does not hear events, right?
Burak
Burak
My thought was the battery was being drained. But I guess that's not the case.
Hi Burak,
Michel,
I doubt it because this problem actually started before the PLM problem, however I am not able confirm this until I get the PLM back online...
Burak
What firmware version is on the sticker inside the battery compartment?
I saw on the Smarthome Forum someone got a replacement with 1.1, Mine are 1.0Bs. Though no data on what was changed.
I'll check tonight.
Burak
After changing the PLM, and moving the MS to a test location, the unit has not repeated the problems I previously had. I'll move the unit to original location tonight to see if it happens again...
Burak
Hi Burak,
Burak
