RainMachine - .5.11 RM
io_guy
RM node server is having issues with the new release. I loaded the new profile and see the additional field areas in the RM device and in programs. However, there is no data in them. My other nodelink devices appear to be fine.
I tried multiple profiles loads of the new profile, multiple restarts of ISY, Nodeserver instance and the pi. I also tried pressing Install ISY Nodes a few times:
2016-08-09 21:36:32 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-11", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual/ISY", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": true, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-09 21:36:32 - RainMachine Poll Error - Argument cannot be null.
Parameter name: s [rainmachi]
2016-08-09 21:37:02 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-09 21:37:02 - {"zones": [{"uid": 1, "name": "Master Valve", "valveid": 1, "ETcoef": 1, "active": true, "type": 1, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": true, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 2, "name": "Zone 2", "valveid": 2, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": false, "soilIntakeRate": 0.0, "detailedMonthsKc": [1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 3, "name": "Zone 3", "valveid": 3, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 4, "name": "Zone 4", "valveid": 4, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 5, "name": "Zone 5", "valveid": 5, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 6, "name": "Zone 6", "valveid": 6, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 7, "name": "Zone 7", "valveid": 7, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 8, "name": "Zone 8", "valveid": 8, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 9, "name": "Zone 9", "valveid": 9, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 10, "name": "Zone 10", "valveid": 10, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 11, "name": "Zone 11", "valveid": 11, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 12, "name": "Zone 12", "valveid": 12, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 13, "name": "Zone 13", "valveid": 13, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 14, "name": "Zone 14", "valveid": 14, "ETcoef": 1, "active": true, "type": 2, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": 0, "soilIntakeRate": 0.0, "detailedMonthsKc": [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 15, "name": "Zone 15", "valveid": 15, "ETcoef": 1, "active": true, "type": 7, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": false, "soilIntakeRate": 0.0, "detailedMonthsKc": [1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1], "permWilting": 0.0, "fieldCapacity": 0.0}}, {"uid": 16, "name": "Unused", "valveid": 16, "ETcoef": 1, "active": false, "type": 1, "internet": true, "savings": 50, "slope": 1, "sun": 1, "soil": 1, "group_id": 0, "history": true, "master": false, "before": 0, "after": 0, "waterSense": {"maxAllowedDepletion": 0.0, "precipitationRate": 0.0, "appEfficiency": 0.0, "allowedSurfaceAcc": 0.0, "rootDepth": 0, "isTallPlant": false, "soilIntakeRate": 0.0, "detailedMonthsKc": [1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1], "permWilting": 0.0, "fieldCapacity": 0.0}}]}(G) [rainmachi]
2016-08-09 21:37:02 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": false, "rainDelayCounter": -1, "rainSensor": false}(G) [rainmachi]
2016-08-09 21:37:02 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-11", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual/ISY", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": true, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-09 21:37:02 - RainMachine Poll Error - Argument cannot be null.
Paul
It's because your "Hot Zones" has a nextRun of "null", didn't see anything like that on my system.  I'll have to handle the null case.
I have it fixed now, will cut a new release tomorrow.
Hello, io_guy,
With Nodelike 5.11, I've been getting the following error:
2016-08-19 07:03:29 - ISY NodeLink Server v0.5.11 started
2016-08-19 07:03:29 - ISY resolved to 192.168.0.30
2016-08-19 07:03:30 - Web config server started (http://192.168.0.2:8090)
2016-08-19 07:03:30 - ISY Node Server config detected (profile 4)
2016-08-19 07:03:32 - Auto-Update: Checking for program update...
2016-08-19 07:03:32 - Auto-Update: No web update available
2016-08-19 07:03:34 - RainMachine Poll Error - String reference not set to an instance of a String.
Parameter name: s [irrigator]
2016-08-19 07:04:05 - RainMachine Poll Error - String reference not set to an instance of a String.
I no longer get a status for my Rainmachine zones and programs in my ISY.
Sorry for not posting this immediately upon the release of 5.11, but I've been away on vacation.
Bumbershoot
Please post the log with verbose enabled so I can see the rain data
Wow, upon restart, the verbose logfile created is nearly 70K of mostly XML in one long string with very little white space.  Plus, it looks like my entire setup is in that XML.  I'm not sure I like the idea of posting all that in a web forum.
Can I get you the data another way, or can I just copy and paste the relevant data from the log if you have a specific search I can use to find it?
Thanks for your time.
Bumbershoot
You can send io_guy a private message using the forum, and attach the log file to that
Paul
Edited by paulbates
Paul
Right you are...  Thanks.
I think you've enabled the wrong verbose.  Not on the log tab, on the rainmachine tab.
Hey Rick
The programs all show up, and disabled programs show as "Not Scheduled" in the AC. If I set them as active in the RM, they show their next scheduled run the AC... all good.
When I try to run the second 2 programs, regardless of if they are active or not active in the RM, the Run button doesn't kick them off from the AC. Nothing seems to happen.. I did have one run where on of them ran, but then it took something like 30 seconds to a minute to get it to turn off... however the first program can be started and stopped with no problems.
The "set errors" are consistent with the issue
2016-08-22 21:21:59 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": true, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": true, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:22:02 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:22:02 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77307, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:22:02 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": true, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": true, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:22:07 - RainMachine Set Error - The remote server returned an error: (404) Not Found. [rainmachi]
2016-08-22 21:22:10 - RainMachine Set Error - The remote server returned an error: (404) Not Found. [rainmachi]
2016-08-22 21:22:14 - { "statusCode":  0,  "message": "OK"                         }(P) [rainmachi]
2016-08-22 21:22:14 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 2, "active": true, "userDuration": 1, "machineDuration": 1, "remaining": 1, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 2, "active": true, "userDuration": 1080.0, "machineDuration": 1080.0, "remaining": 1080.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 2, "active": true, "userDuration": 1080.0, "machineDuration": 1080.0, "remaining": 1080.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:22:14 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77295, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:22:14 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": true, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 2, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": true, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:22:15 - { "statusCode":  0,  "message": "OK"                         }(P) [rainmachi]
2016-08-22 21:22:15 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:22:15 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77293, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:22:16 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": true, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": true, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:22:32 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:22:32 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77277, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:22:32 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": false, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": true, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:23:02 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:23:02 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77247, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:23:02 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": false, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:23:27 - RainMachine Set Error - The remote server returned an error: (404) Not Found. [rainmachi]
2016-08-22 21:23:33 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:23:33 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77216, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:23:33 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": false, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:24:03 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:24:03 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77186, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:24:03 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": false, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:24:33 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:24:33 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77156, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:24:33 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": false, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:25:03 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:25:04 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77125, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:25:04 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": false, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:25:10 - { "statusCode":  0,  "message": "OK"                         }(P) [rainmachi]
2016-08-22 21:25:10 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 2, "active": true, "userDuration": 1, "machineDuration": 1, "remaining": 1, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 2, "active": true, "userDuration": 1440.0, "machineDuration": 1440.0, "remaining": 1440.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 2, "active": true, "userDuration": 1440.0, "machineDuration": 1440.0, "remaining": 1440.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 2, "active": true, "userDuration": 1440.0, "machineDuration": 1440.0, "remaining": 1440.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 2, "active": true, "userDuration": 1440.0, "machineDuration": 1440.0, "remaining": 1440.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 2, "active": true, "userDuration": 1320.0, "machineDuration": 1320.0, "remaining": 1320.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 2, "active": true, "userDuration": 960.0, "machineDuration": 960.0, "remaining": 960.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 2, "active": true, "userDuration": 1200.0, "machineDuration": 1200.0, "remaining": 1200.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 2, "active": true, "userDuration": 1440.0, "machineDuration": 1440.0, "remaining": 1440.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 2, "active": true, "userDuration": 1440.0, "machineDuration": 1440.0, "remaining": 1440.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 2, "active": true, "userDuration": 1200.0, "machineDuration": 1200.0, "remaining": 1200.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 2, "active": true, "userDuration": 1080.0, "machineDuration": 1080.0, "remaining": 1080.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 2, "active": true, "userDuration": 1200.0, "machineDuration": 1200.0, "remaining": 1200.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 2, "active": true, "userDuration": 1200.0, "machineDuration": 1200.0, "remaining": 1200.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 2, "active": true, "userDuration": 1440.0, "machineDuration": 1440.0, "remaining": 1440.0, "cycle": 1, "noOfCycles": 1, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:25:10 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77119, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:25:10 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 1, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": false, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
2016-08-22 21:25:17 - { "statusCode":  0,  "message": "OK"                         }(P) [rainmachi]
2016-08-22 21:25:17 - {"zones": [{"uid": 1, "name": "Master Valve", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": true, "waterSense": false}, {"uid": 2, "name": "Zone 2", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 3, "name": "Zone 3", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 4, "name": "Zone 4", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 5, "name": "Zone 5", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 6, "name": "Zone 6", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 7, "name": "Zone 7", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 8, "name": "Zone 8", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 9, "name": "Zone 9", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 10, "name": "Zone 10", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 11, "name": "Zone 11", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 12, "name": "Zone 12", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 13, "name": "Zone 13", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 14, "name": "Zone 14", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 2, "master": false, "waterSense": false}, {"uid": 15, "name": "Zone 15", "state": 0, "active": true, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 7, "master": false, "waterSense": false}, {"uid": 16, "name": "Unused", "state": 0, "active": false, "userDuration": 0, "machineDuration": 0, "remaining": 0, "cycle": 0, "noOfCycles": 0, "restriction": false, "type": 1, "master": false, "waterSense": false}]}(G) [rainmachi]
2016-08-22 21:25:17 - {"hourly": false, "freeze": false, "month": false, "weekDay": false, "rainDelay": true, "rainDelayCounter": 77112, "rainSensor": false}(G) [rainmachi]
2016-08-22 21:25:17 - {"programs": [{"uid": 1, "name": "Main Program", "active": true, "startTime": "01:30", "cycles": 3, "soak": 480, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 1, "param": "3"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": "2016-08-23", "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1440, "active": true}, {"id": 3, "name": "Zone 3", "duration": 1440, "active": true}, {"id": 4, "name": "Zone 4", "duration": 1440, "active": true}, {"id": 5, "name": "Zone 5", "duration": 1440, "active": true}, {"id": 6, "name": "Zone 6", "duration": 1320, "active": true}, {"id": 7, "name": "Zone 7", "duration": 960, "active": true}, {"id": 8, "name": "Zone 8", "duration": 1200, "active": true}, {"id": 9, "name": "Zone 9", "duration": 1440, "active": true}, {"id": 10, "name": "Zone 10", "duration": 1440, "active": true}, {"id": 11, "name": "Zone 11", "duration": 1200, "active": true}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": true}, {"id": 13, "name": "Zone 13", "duration": 1200, "active": true}, {"id": 14, "name": "Zone 14", "duration": 1200, "active": true}, {"id": 15, "name": "Zone 15", "duration": 1440, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 3, "name": "Hot Zones - Manual ISY", "active": false, "startTime": "12:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 1080, "active": true}, {"id": 3, "name": "Zone 3", "duration": 0, "active": false}, {"id": 4, "name": "Zone 4", "duration": 0, "active": false}, {"id": 5, "name": "Zone 5", "duration": 1080, "active": true}, {"id": 6, "name": "Zone 6", "duration": 0, "active": false}, {"id": 7, "name": "Zone 7", "duration": 0, "active": false}, {"id": 8, "name": "Zone 8", "duration": 0, "active": false}, {"id": 9, "name": "Zone 9", "duration": 1080, "active": false}, {"id": 10, "name": "Zone 10", "duration": 1080, "active": false}, {"id": 11, "name": "Zone 11", "duration": 1080, "active": false}, {"id": 12, "name": "Zone 12", "duration": 1080, "active": false}, {"id": 13, "name": "Zone 13", "duration": 1080, "active": false}, {"id": 14, "name": "Zone 14", "duration": 1080, "active": false}, {"id": 15, "name": "Zone 15", "duration": 1080, "active": false}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}, {"uid": 6, "name": "Fertilizer - Manual", "active": false, "startTime": "00:00", "cycles": 0, "soak": 0, "cs_on": false, "delay": 0, "delay_on": false, "status": 0, "startTimeParams": {"offsetSign": 0, "type": 0, "offsetMinutes": 0}, "frequency": {"type": 0, "param": "0"}, "coef": 0.0, "ignoreInternetWeather": false, "futureField1": 0, "freq_modified": 0, "useWaterSense": false, "nextRun": null, "simulationExpired": false, "wateringTimes": [{"id": 1, "name": "Master Valve", "duration": 0, "active": false}, {"id": 2, "name": "Zone 2", "duration": 600, "active": true}, {"id": 3, "name": "Zone 3", "duration": 600, "active": true}, {"id": 4, "name": "Zone 4", "duration": 600, "active": true}, {"id": 5, "name": "Zone 5", "duration": 600, "active": true}, {"id": 6, "name": "Zone 6", "duration": 600, "active": true}, {"id": 7, "name": "Zone 7", "duration": 600, "active": true}, {"id": 8, "name": "Zone 8", "duration": 600, "active": true}, {"id": 9, "name": "Zone 9", "duration": 600, "active": true}, {"id": 10, "name": "Zone 10", "duration": 600, "active": true}, {"id": 11, "name": "Zone 11", "duration": 600, "active": true}, {"id": 12, "name": "Zone 12", "duration": 600, "active": true}, {"id": 13, "name": "Zone 13", "duration": 600, "active": true}, {"id": 14, "name": "Zone 14", "duration": 600, "active": true}, {"id": 15, "name": "Zone 15", "duration": 600, "active": true}, {"id": 16, "name": "Unused", "duration": 0, "active": false}]}]}(G) [rainmachi]
Yep, the issue is the uid of the program doesn't match the "index".  i.e. Program 2 doesn't have uid 2 (kind of odd for RainMachine not to sync these).  I'll fix this in the next release.
I think you've enabled the wrong verbose.  Not on the log tab, on the rainmachine tab.
Okay, sorry.  I see that now.  Interestingly, the issue seems resolved with 5.12.  Are you still interested in the logs?
Bumbershoot
Edited by Bumbershoot
Nope, you likely had the same issue Paul had (program parsing).
