October 1, 200719 yr When right-clicking a node and selecting "Move to scene": "Move" is a little misleading. I think (correct me if I'm wrong) that this should instead read "Add to Scene" Move incorrectly implies it will also be REMOVED from the current scene, or "My Lighting".
October 2, 200719 yr sceaton, Sounds good. We shall review and implement. With kind regards, Michel When right-clicking a node and selecting "Move to scene": "Move" is a little misleading. I think (correct me if I'm wrong) that this should instead read "Add to Scene" Move incorrectly implies it will also be REMOVED from the current scene, or "My Lighting".
October 2, 200718 yr Author In addition, it should probably also have an ellipses to indicate that this isn't a final "command" but rather a link to another dialog: Add to Scene...
October 2, 200718 yr Good idea, I suggested this a while back. The guys asked me to suggest the commands to do this to. I guess I should get that list together.
October 2, 200718 yr sceaton, Thanks. Already done and will be available in the next release. With kind regards, Michel In addition, it should probably also have an ellipses to indicate that this isn't a final "command" but rather a link to another dialog: Add to Scene...
