Thermostat
TheWabit
How often should the ISY get updated on the temperature and set status of the thermostat? I have looked often and noticed the ISY doesn't match what the tstat says. I have created a program with the fanlinc - the wrong information is not triggering the fan when it should.
Posted (edited)
One of my several thermostats doesn't always update the ISY. A workaround, if possible, depends on your specific program. Post it here (right click on the program name, select Copy to Clipboard).
Edited by stusviews
Bonus Room Fan - [iD 0038][Parent 0001]
        Status  'Upstairs Tstat' >= 77° (Temperature)
        Set 'Bonus Room Fanlinc - Motor' High
        Wait  10 seconds
        Set 'Bonus Room Fanlinc - Motor' Med
        Set 'Bonus Room Fanlinc - Motor' Off
Hi Michel,
It is Insteon and I DO get a change in Admin (set point number) after changing the set point manually. More times than not, the set point number updates but the temperature doesn't.
Hi TheWabit,
Thank you. If you have reliable communications with it otherwise, AND if it's a SmartLabs thermostats (the ones with blue screens), it might be because it's not powered (it's on battery) or that it's not set in master mode (alas I do not remember how to put it back in master mode).
There's a button under the front panel labelled MASTER. It's functional only if a wired and wireless thermostat are linked.
I did press and hold the master button until it beeped and "master" appeared on the screen. however, I have no wireless units attached to it. I guess we will see what happens.
Is that on the display or what the ISY reports?
Interesting. My Insteon thermostats indicate .5º increments. Do you have the thermostat set for ºF or ºC?
My 2441ZTH displays every 0.5º C also but it doesn't send updates to ISY until about a 1.5º C change.
I assume that equates to about the same as your 2.x degrees F.
My zth behaves the same as Larry's.
Last time I factory reset both my 2441ZTH stats, as I thought perhaps v5.0.4 may have fixed some parameters not being settable,  I had to factory reset one about 8-9 times before it would link and update properly with ISY.  The newer unit had to be factory reset twice before behaving. Each time different parameters wouldn't work.
Of course ISY has no profile  information (not listed as a device)  for the 2441ZTH, only the 2441TH stat. Sure it reads the model and version from the stat and displays it but no controls work on one and only some do on the older version firmware.
If UDI doesn't have the API to fully support a device in 4+, then the device won't be fully supported in 5+. That's not to say that 5+ isn't more advanced than 4+ nor that 5+ doesn't have more features. But those features are not tied to any particular device.
Having access to a device's set of instructions matters as well as the routines available.
That would have been my two cents until Canada eliminated pennies B)
So here is an update - I think it is updating now. I did 3 things - don't know which one worked.
1) I had the ISY going through a network switch. I illiminated the switch and went direct to the Ethernet port (although, that Ethernet port eventually gets to a router).
2) Factory reset the Thermostat
3) Removed the Tstat from the ISY and re-added.
Seems to be working.
Mine have taken 3-12 tries to link properly.
Congrats on being stubborn!
      38k
      379.2k
