hum099 Posted September 15, 2016 Posted September 15, 2016 Does the ISY portal allow you to view internal cams (they are in Mobilinc) from outside the network. I can see all my switches using the Mobilinc app with the ISY portal. They are Axis web cams.
Michel Kohanim Posted September 15, 2016 Posted September 15, 2016 Hi hum099, As long as you have port forwarded to them, yes. With kind regards, Michel
hum099 Posted September 15, 2016 Author Posted September 15, 2016 Thanks Michel Any security issues with port forwarding I need to be aware of before I do it.
MWareman Posted September 15, 2016 Posted September 15, 2016 Thanks Michel Any security issues with port forwarding I need to be aware of before I do it. It's likely that your cameras would have to support SSL, otherwise you may get a mixed content warning (and some browsers won't render).
