Have ISY notify me when lock battery is getting low?
danbutter
This seems like a simple thing, but I can't get it to work.
Running 5.0.2.  Kwikset lock.
I DO get notified when I enter a certain pin on this lock, but for some reason the battery level doesn't work for me.
I tried:
IF Status (old) lock = 40% battery level
THEN send notification to me
ELSE nothing
I tested the notification and it works fine and I get lots of others from ISY.  No issue there.
So I figured that maybe the ISY never sees the exact number of 40% and changed it to <=40%
Saved the program and waited.  Nothing.
I queried the lock.  ISY says it is locked and at 30% battery.
So Am I missing something or??
Any thoughts?
Until the battery status changes from the 30% you observe the program will not trigger, so you'll have to wait until it goes below 30% (or above).
Edited by andyf0
Even though I have the program looking for less than or equal to 40% and the ISY can see the battery at 30%?
The ISY is event-based. It only does something when an event takes place (ie. something changes)
Sent from my SM-N910W8 using Tapatalk
Also per your program, every time it changes, it will notify you (at 29%, 28%, 27%, ...)
Well I took out and added new batteries and then put the old ones back in and it finally worked.  I guess the key was the <= since it likely never reported the exact number of 40%.
Thanks to all who chimed in!
      37.5k
      375.5k
