Statuses on a couple of my requests
At one time I had requested the ability to set a wildcare year for an event so you could have something run every year at the same day and time.  The other was the ability to store the config for the gui in some place other than the devault Java directory.  Any feedback on these would be appreciated.  Thank you.
Ok, thank you.  Just thought I would check since I hadn't seen anything about them.
I use a variable in v5.0.4 to keep the date in format MM.DD
This takes a separate program, but other programs can then use the $sMM.DD to test for date ranges, year independant.
