Amazon IOT button
Nope, the network module doesn't do anything for those.
I looked at the API for those some time ago -- they contact an Amazon-owned service, which then calls to your AWS-hosted service to deal with the event.  In other words, in addition to being dependent on Amazon's cloud-based service, the device would also be dependent upon your own cloud-based service -- which ultimately could contact the UDI portal, which could relay the event to your ISY.
That's three separate cloud-bases services, all hosted in Amazon's cloud -- just for a button in my house to send a message to the ISY in my house.  Yikes!  Rube Goldberg would be proud of the state of IoT these days...
Has anyone played with this yet? I assume the network module would support it?
Take a look at this, maybe it will work for you.
Push/press/click: A smart button roundup
https://ifttt.com/blog/2016/09/push-press-click--a-smart-button-roundup?utm_content=buffer3b633&utm_medium=social&utm_source=twitter.com&utm_campaign=buffer
Yikes is right.  That's not a good way to go.
Thanks!  Have you used any of these with the ISY?
Nope - but you could send a maker URL via IFTTT to the ISY to trigger something.
I see a market for a tiny Arduino device in a button that connects to the local wifi network, and can call arbitrary URL, like the ISY directly....
I may disassemble that silly 'Easy' button I've had for a while....
Edit. Looks like the Adafruit Feather HUZZAH will do it. Arduino compatible tiny device with a full wifi stack. Battery charging circuit is onboard as well, all for $16 (US). One of those is going into my easy button.... :)
Edited by MWareman
Will it still say "That was easy!" when you push it?
Sent from my SM-N910W8 using Tapatalk
Get the sound file and have it play via the Elk security speaker when its pressed. Lol
I've been playing with the Adafruit ESP8266 "Feather" HUZZAH -- it's basically arduino-like, but has built-in WiFi.   I flashed the MicroPython firmware on it, and that works marvelously for integration with the ISY.
I was planning on writing something up on this at some point... but time is an issue as always!
[edited to add:  to date, I only have it updating variables via REST on the ISY -- but I'm toying with the idea of trying to implement a low-power, low-speed, low-update-rate, low-everything Node Server...]
