nolan11 Posted October 8, 2016 Posted October 8, 2016 Hello, I have a few programs setup in my ISY using Insteon Dual Band dimmer switches and a PLM. The Programs are setup to come one everyday at sunset. Problem is not all of the lights come on. I even have the program setup to send the signal twice more after the first attempt providing it the command "wait 4 seconds" (Screen shot attached) I am lost as to why these lights are not coming on. They used to with no problem at all, but I had a PLM die on me and I had to replace it. I know it works because it does turn on other lights in the program. Keep in mind, this is random. Some nights all lights come on, some nights 1 or 2 lights do not come on. I do have the latest firmware also. Any ideas? Thanks, Bruce
larryllix Posted October 8, 2016 Posted October 8, 2016 Check the links in each device and then do a compare with what ISY thinks should be in the device. Usually links are lost or scrambled. Use restore on each device to resync.
nolan11 Posted October 8, 2016 Author Posted October 8, 2016 Check the links in each device and then do a compare with what ISY thinks should be in the device. Usually links are lost or scrambled. Use restore on each device to resync. I will do that but I have no idea what I am actually looking for to determine if a link should or shouldn't be there.
larryllix Posted October 8, 2016 Posted October 8, 2016 The compare will be self-explanatory. UDI has done all the compares for you I will do that but I have no idea what I am actually looking for to determine if a link should or shouldn't be there. The compare result will be self-explanatory. UDI has done all the work for you and will hightlight differences and errors.
