Blackbird Posted October 23, 2016 Share Posted October 23, 2016 I wanted to write a program for my water shutoff which is on output 3 but in the programs for output, it is from 065 to 208. Any idea why? Link to comment Share on other sites More sharing options...
DennisC Posted October 23, 2016 Share Posted October 23, 2016 I wanted to write a program for my water shutoff which is on output 3 but in the programs for output, it is from 065 to 208. Any idea why? Outputs 1 - 64 do not automatically show up in the ISY. You will need to enable output 3 first in the ELK RP software. To do this, connect to your panel with Elk RP, choose Automation, Outputs, and then put a check mark in the "show" box. After doing this send it to the control and save the database and close out of Elk RP. Next, go back to your ISY and you should be able to see output 3 under Elk - Outputs tab. Once it is there, you can use it in a program. Also, you can rename output 3 in the ELK RP software to give it a friendly name. Dennis Link to comment Share on other sites More sharing options...
Blackbird Posted October 23, 2016 Author Share Posted October 23, 2016 I followed the instructions you gave but it still isn't showing up in iys. Does the ISY need to be reset? Link to comment Share on other sites More sharing options...
Blackbird Posted October 23, 2016 Author Share Posted October 23, 2016 I had to select, Refresh topology in the ISY then they appeared. Thanks a lot! Link to comment Share on other sites More sharing options...
DennisC Posted October 24, 2016 Share Posted October 24, 2016 Glad it's working. Link to comment Share on other sites More sharing options...
