ELK Beta testing
James Peterson
I'm on a Samsung S7.
Touching on the location in your image closed that screen.
Also, on my Nexus 6P running 7.1.1 Agave crashes.
B.R.I.A.D.A.
Best regards,
Gary Funk
B.R.I.A.D.A.
Best regards,
Gary Funk
I don't see any crash reports?  Loading a 6P 7.1.1 emulator to test...
The application closes before I can do anything.
Edit: I sent you a crash report.
B.R.I.A.D.A.
Best regards,
Gary Funk
I have identified the bug and can recreate it 100%.
I. S. B. S. P.
Best regards,
Gary Funk
When you say identified.  can  you be more specific about what you identified.  :)
When I scroll down to a specific scene it crashes. When I type that scene into search it crashes.
I can give you access to my system if it helps.
B.R.I.A.D.A.
Best regards,
Gary Funk
B.R.I.A.D.A.
Best regards,
Gary Funk
Just PM me a node dump.
I am running the 1.5.005 Beta on a Samsung Galaxy S6. I can arm the Elk using Agave, but I cannot disarm it. I tried using both a direct connection, and via the Portal, and neither method works. For the record, I can disarm the Elk using Michael's Home Alarm app.
hrm...?  Do you require a keycode?  Is the keypad being displayed when you go to disarm?  What error is displayed?  Are any of your zones in a non-standard state?  maybe I missed something on that end?
Yes. I require a keycode to disarm my system. When I tap the big "E" logo, a kepad is indeed displayed. I then type in my code and hit "Disarm". Nothing happens. There is no error displayed. The code simply does nothing.
Everything else seems to be working. I can arm the system using Agave, and it properly displays the status such as Armed, Disarmed, etc ... It also correctly indicates the state of all the zones. The only thing that isn't working is the disarming.
OK, that gets me a little closer.  So nothing happens at all.  I just want to make sure.  When the passcode is accepted the keypad should close and return you to the status screen.  Is this happening?
No. It stays on the keypad screen, and the dots used to obfuscate the code remain.
I just installed Agave on a Samsung Galaxy tablet to see if I would have any better luck. Unfortunately, I still have the same problem with this device as well. The only difference is that when I hit the Disarm button, an "Update Failed" message briefly appears near the bottom of the keypad. This message is not displayed on my phone.
OK.  that tells me where its failing.  just need to determine why now.  I'll see if I can get a new apk built tonight to do that.
You da man, James!  :-)
James,
I defined all six function key but only three show up and even they are wrong.
B.R.I.A.D.A.
Best regards,
Gary Funk
James,
B.R.I.A.D.A.
Best regards,
Gary Funk
Since I do have access to you system, I just checked.  From what I am seeing in the data, the keys are displaying correctly.   maybe you need to re-sync the ISY.
This is from the ISY.
B.R.I.A.D.A.
Best regards,
Gary Funk
B.R.I.A.D.A.
Best regards,
Gary Funk
Seems to be working now.  Long press on the top left Elk Shield to force ELK data reload.
Oh.
Clearly I need to read the manual.
B.R.I.A.D.A.
Best regards,
Gary Funk
Oh.
B.R.I.A.D.A.
Best regards,
Gary Funk
Clearly I need to make a manual.  but all of this is still testing so, I feel no need to mention features that may not stick around.
I borrowed an S5 and S7 from my work test devices and could not reproduce the error.  Does anyone else experience this?
Could you try long pressing on the top left ELK Shield and refreshing data to see if that fixes anything?
