Force a device to beep?
Under program actions for an Insteon device, you have the option in the pulldown list for the device to beep.
Edited by bgav
Hint:  You can also use 'Beep' with a scene, causing multiple devices to sound off (nearly) simultaneously.
The "beep duration" is value is ignored by all known Insteon devices, all durations give the same length and volume beep.
The IR Transmitter I received supported the beep duration right up until the firmware inside crashed and I am waiting for the R MA final papers. :)
Maybe Supernan could make use of it with enhanced hearing.
