Scene problem (light goes on 100%, the 10 sec later @ 50%?
Hi,
I have four devices:
Front Porch
Front Lights
Backyard Lights
Deck Lights
All in a scene called "Outside".
When I press the front porch light (controller) the other three lights (responders) should all turn on. Basically one light turns all the outside lights on or off.
I had originally set this manually (linked by hand). I then wanted to control it all through ISY.
I deleted the links & created that outside scene. I started to notice that after I turned the porch light on, the "front" lights dim to what looks like 50% but the ISY seems to think its 100%.
Any ideas how to fix this?
EDIT1: This is all local at the switch.
Rich
EDIT: I deleted the scene, then pressed the porch on button (locally) & only the porch turned on, I added the scene again & again the front lights come on, then dim.
Unless you have a lot of links for these devices already, I would remove them from ISY, perform a factory reset on each one and then readd them and recreate the scene. That will insure that all the previous links have been removed.
I have a few scenes
(all out)
(my lighting)
(Outside)
That all uses those items.
Should I factory reset that outside front light that dims to 50%?
I also am unsure why ISY doesnt see that the front light change from 100% to 50% (my estimate on brightness).
Hi Rich,
Perhaps it would be a good idea for you to contact our tech support (if you have remote access enabled) and let them walk through it with you.
I have a few scenes
(all out)
(my lighting)
(Outside)
