slpelts Posted November 29, 2016 Posted November 29, 2016 I am unable to add this device manually or otherwise to the ISY. I get error msg "Cannot Determine Insteon Engine" not sure how to resolve this. it is a new device as of yesterday thanks
Brian H Posted November 29, 2016 Posted November 29, 2016 Try Factory Resetting the module. Then try adding it into your system. You may want to have the Event Viewer in Level 3 open so you can capture the communications between the 2457D2 and the ISY994i.
Techman Posted November 29, 2016 Posted November 29, 2016 I am unable to add this device manually or otherwise to the ISY. I get error msg "Cannot Determine Insteon Engine" not sure how to resolve this. it is a new device as of yesterday thanks You have a communication problem between the module and the PLM which could be caused by interference on the poweline or a weak Insteon mesh network. Without knowing more about your setup it's difficult to provide a solution. Try doing a factory reset on the module then move the module closer, and on the same circuit, to the PLM and then try linking it again to the ISY.
slpelts Posted November 29, 2016 Author Posted November 29, 2016 reset it and plugged into same line as controller. still cannot determine. I guess it is bad?
Teken Posted November 29, 2016 Posted November 29, 2016 reset it and plugged into same line as controller. still cannot determine. I guess it is bad? What model of controller (99 vs 994) do you have and what is the UI / Firmware in use under Help -> About?
slpelts Posted November 29, 2016 Author Posted November 29, 2016 ISY994i/IR Pro UI Insteon_UD994 v4.5.1 Firmware Insteon_UD994_OADR v.4.5.4
Teken Posted November 29, 2016 Posted November 29, 2016 ISY994i/IR Pro UI Insteon_UD994 v4.5.1 Firmware Insteon_UD994_OADR v.4.5.4 Please down load the correct UI for the firmware in place and clear out the Java Cache ensuring (ALL) check box's are selected and try again.
slpelts Posted November 29, 2016 Author Posted November 29, 2016 where/how do I get the correct UI? i did an upgrade earlier today so I assumed it would have do it but guess not?
slpelts Posted November 29, 2016 Author Posted November 29, 2016 ok install and tried again. New Error now Cannot determine device link table address thanks
slpelts Posted November 29, 2016 Author Posted November 29, 2016 after third try it finally added. thanks for the help
Teken Posted November 29, 2016 Posted November 29, 2016 ok install and tried again. New Error now Cannot determine device link table address thanks Hello Slpelts, Can you try using both methods while the level 3 diagnostic logs are running and upload those logs to the forum when completed. When I say try both methods you have the option of selecting the two colored whirling arrows or the light bulb. Using the light bulb option requires you to enter the Insteon ID correctly. Meaning place ensure you don't confuse a 8 vs B / 0 vs o etc. Using the two colored whirling arrows simply requires you to press that icon and then press the set button until it goes into linking mode. More often than not it will beep once the ISY Series Controller detects the unit and begins the adding process. Please use both and let us know the outcome with the logs so we can see what is happening in each case. after third try it finally added. thanks for the help LOL - Ignore what I just wrote then!
