kimbray Posted December 3, 2016 Posted December 3, 2016 I have two V1.0 Access Points and I am trying to determine the sync process again for phase 1 and 2 set up. I install the first one and hit sync button and LED gets bright. I install the second and hit sync and depending on outlet it starts flashing quickly or slowly blinks. I believe based on placement, when slowly blinks, it is on different phase, but wanted to validate. Thanks
stusviews Posted December 3, 2016 Posted December 3, 2016 Tap the set button on the first AP four time very, very rapidly. The LED will remain bright. If it doesn't then you didn't tap four times rapidly enough. then observe the LED on the second AP. If the second LED is steady bright, then you've accomplished bridging in that direction. If the LED is blinking or dim, try a different outlet. Now reverse which is the first AP and test again.
Teken Posted December 3, 2016 Posted December 3, 2016 Information Only: http://static.highspeedbackbone.net/pdf/S56-1058-%20Manual.pdf
