How to find insteon address of 2456d3
jongig
I have a ISY994Ir and I'm trying to link a ApplianceLinc but the address sticker must have fallen off the ApplianceLinc. Is there any way to connect this to the ISY?
You should be able to put it in linking mode and manually link it.a69fcb26872fcab45957f0e616831dbe.jpgUse the Icon with the circling arrows.
I'm Gary Funk. Pay no attention to this message.
Link to comment
Share on other sites
Not having tried this I will tell you what I understand works.
Side link the ApplianceLinc to another say...switchLinc.
Run admin consle and display the event viewer, level 3
Activate the switchlinc to send a code to the ApplianceLinc.
Look for the Insteon traffic codes with the addresses contained in it and try it.
If it links then write it on the AppLinc.
Link to comment
Just use the Link Management
New Device.
Start Linking choice.
Push the Set Button on the Appliancelinc until it is discovered.
Then hit the finish button on the start linking screen.
It should be added to the ISY994i setup.
Larry's method also works. I had to go that route with a Controllinc Smarthome pulled the labels off and sold it as an X10 controller but didn't change the firmware.
Link to comment
