Network Resources - Can't Copy or Paste ?
Haven't updated or changed any of my network resources (or anything other than simple ISY stuff) lately, but now can't paste anything into Network resources. Is this normal? I don't remember this issue and I've got lots of network resources I set up previously.
Need to do some Philips Hue Network Resources and they involve long ID numbers and such.
Windows machine, obviously operating on the Admin Console.
Right-clicking does nothing. Rebooted PC etc.... but no change.  Maybe I'm just getting old and it never would allow copy / paste?
Thanks for any insight.
I don't think the admin console ever allowed pasting on a windows OS. Maybe in the URL I may have used it.
I use the copy NR function, and then modify, to expedite things similar.
Should be able for use control-v to paste?
Sent from my Pixel C using Tapatalk
That is what I do and it works. Control-C and Control-V
Thanks for suggestions. I know I'd primarily copied the whole resource and changed the pertinent stuff in the past (as pointed out) but thought I'd been able to copy / paste. Using the old keyboard shortcuts didn't occur to me (but should have!).
Just wanted to make sure I hadn't totally lost it.
Thanks for the info!
I just did a test and the windows keyboard shortcuts appear to work OK in the admin console for win 7.
I always use the original key shortcuts though. <shift><del> and <shift><insert>. Touch screen based machine don't like to support key shortcuts, unfortunately, so you have to do some finger contortions, and physiotherapy later, for your crabApple fingers. :)
