2441TH Fan Node Missting on ISY / WIKI Question
The WIKI page covering Thermostats ( https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Linking_a_Thermostat )
States there should be 4 nodes:
  • The main node - this is the main thermostat node
  • Cool Control - indicates when the thermostat is calling for Cool
  • Heat Control- indicates when the thermostat is calling for Heat
  • Fan Control - indicates when the fan is on/off
I have deleted and relinked my device a few times and I only ever get 3 nodes
Main, cool, and heat.
Is this expected and the WIKI needs to be updated?  How do I check the current status of the fan on the furnace?
The Smarthome manual
http://cache-m2.smarthome.com/manuals/2732-xx2-en.pdf
Has the following:
Group 1-Cooling mode change (scene control)
Group 2-Heating mode change (scene control)
Group 3-Dehumidifiation, high humidity setpoint (scene control)
Group 4-Humidification, low humidity setpoint (scene control)
Group EF - Broadcast on any change (notification group for linked software controllers)
I don't think groups match up with Nodes in ISY, but it is interesting, and would be curious to know how things match up.
Ok so a 'node' doesn't always mean an entry in the ISY like the Main, Head Ctl and Cool Ctl?
All my 2441 thermostats (3 wired, 4 wireless) show only three nodes, main, heat and cool. But, I can trigger a program based on the state of the fan and/or use a program to control the state of the fan.
