Best way to manage programs
I want to use the ISY to control 5 landscape pumps.
So, for the Spring & Fall, I wrote a set of programs that will exercise the pumps periodically each day.
However, for the hottest of summer or to prevent freezing, I need a completely different set of programs.
The only way I can figure out so far is to create a set of programs for a time of year, then back them up to a file.  Clear the programs out, then start over with a new set for different conditions, then backing them up to a new name.
By restoring the correct backup, I get the set of programs that are right for those conditions.
1. Is there a more elegant way to do this?
2. I assume that all I need to do is do an "all stop" to all the pumps before I restore from the backup and everything will start over fresh with the new programs. Correct?
Have you considered putting each set of programs in its own folder and then disabling the folders you don't want to run?
Also, could you base each folder on outside temperature?
Gary Funk
Merry Christmas
Placing the seasonal programs in folder is a good idea. It's not possible to disable a program folder, but it's easy to created a condition that's true or false:
Folder Conditions for 'Spring'
        $iRun_Spring is 1
Thank you, Stu. I've never used folder programming.
Gary Funk
Merry Christmas
Even easier is to create one state variable for all seasons, then change only the variable:
        $sRun_Season is 1
Folder Conditions for 'Fall'
        $sRun_Season is 2
etc.
then add a program to change the variable:
Spring
        From    Sunrise on date_to_start
        To      Sunrise on date_to_end
        $sRun_Season  = 1
Fall
        $sRun_Season  = 2
etc.
Edited by stusviews
Folder conditions, like program conditions, will not trigger on an Integer variable.
The variables must be state type variables or nothing will happen.
I just tested this to be true again.
Thanks for the reminder. I corrected my post to reflect the correction.
