Can't Add INSTEON 2443-222 Micro On/Off Module
milhouse
Hi,
I'm having trouble adding a mMcro on/off to my ISY. Before I pull my hair out, I can't tell if its a load issue or a communication issue, so any help would be appreciated. FWIW, its connected to two sconces, each with 2 30 Watt Edison Bulbs (non-LED) for a total of 120 Watts. They respond correctly to physically pressing the On Off buttons.
Standard linking (Selecting Add Device and holding the set button 3-5 seconds) produces beeps from the module, but there is nothing in the software that indicates it found it.
Adding by address usually causes the module to beep a few times like its communicating, but then I get the following errors (and the Level 3 Log is below):
Thanks in advance...
Wed 12/14/2016 07:42:05 PM : [3b 43 94    ] Added to list of devices to link to ISY
Wed 12/14/2016 07:42:29 PM : [3B 43 94 0  ] Failed to add device, reason 3
Wed 12/14/2016 07:42:29 PM : [All         ] Writing 1 bytes to devices
Wed 12/14/2016 07:42:52 PM : [  36 8C 29 1]      ERR   1
Wed 12/14/2016 07:43:45 PM : [3b 43 94    ] Added to list of devices to link to ISY
Wed 12/14/2016 07:43:45 PM : [iNST-TX-I1  ] 02 62 3B 43 94 0F 0D 00
Wed 12/14/2016 07:43:45 PM : [iNST-ACK    ] 02 62 3B.43.94 0F 0D 00 06                 (00)
Wed 12/14/2016 07:43:45 PM : [iNST-SRX    ] 02 50 62.43.94 30.DD.F9 A7 0D FF           (FF)
Wed 12/14/2016 07:43:45 PM : [std-Direct Nack] 62.43.94-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 12/14/2016 07:43:45 PM : [iNST-DUP    ] Previous message ignored.
Wed 12/14/2016 07:43:54 PM : [iNST-TX-I1  ] 02 62 3B 43 94 0F 0D 00
Wed 12/14/2016 07:43:54 PM : [iNST-ACK    ] 02 62 3B.43.94 0F 0D 00 06                 (00)
Wed 12/14/2016 07:43:54 PM : [iNST-SRX    ] 02 50 62.43.94 30.DD.F9 A7 0D FF           (FF)
Wed 12/14/2016 07:43:54 PM : [std-Direct Nack] 62.43.94-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 12/14/2016 07:43:54 PM : [iNST-DUP    ] Previous message ignored.
Wed 12/14/2016 07:44:03 PM : [iNST-TX-I1  ] 02 62 3B 43 94 0F 0D 00
Wed 12/14/2016 07:44:03 PM : [iNST-ACK    ] 02 62 3B.43.94 0F 0D 00 06                 (00)
Wed 12/14/2016 07:44:04 PM : [iNST-SRX    ] 02 50 62.43.94 30.DD.F9 A7 0D FF           (FF)
Wed 12/14/2016 07:44:04 PM : [std-Direct Nack] 62.43.94-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 12/14/2016 07:44:04 PM : [iNST-DUP    ] Previous message ignored.
Wed 12/14/2016 07:44:04 PM : [iNST-SRX    ] 02 50 3B.43.94 30.DD.F9 A3 0D FF           (FF)
Wed 12/14/2016 07:44:04 PM : [std-Direct Nack] 3B.43.94-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Wed 12/14/2016 07:44:04 PM : [iNST-TX-I2CS] 02 62 3B 43 94 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
Wed 12/14/2016 07:44:04 PM : [iNST-ACK    ] 02 62 3B.43.94 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01)
Wed 12/14/2016 07:44:04 PM : [iNST-SRX    ] 02 50 3B.43.94 30.DD.F9 27 09 01    LNK-ON (01)
Wed 12/14/2016 07:44:04 PM : [std-Direct Ack] 3B.43.94-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 12/14/2016 07:44:05 PM : [LNK-BGN     ] 02 64 01 00 06
Wed 12/14/2016 07:44:06 PM : [LNK-STAT    ] 02 53 M(01) gid=00 53.43.94 022F 48
Wed 12/14/2016 07:44:06 PM : [iNST-TX-I1  ] 02 62 3B 43 94 0F 0D 00
Wed 12/14/2016 07:44:06 PM : [LNK-END     ] 02 65 06
Wed 12/14/2016 07:44:06 PM : [std MH      ] Unexpected Ack imCmd=65 cmd1= 0x94
Wed 12/14/2016 07:44:06 PM : [iNST-ACK    ] 02 62 3B.43.94 0F 0D 00 06                 (00)
Wed 12/14/2016 07:44:07 PM : [iNST-SRX    ] 02 50 62.43.94 30.DD.F9 A7 0D FF           (FF)
Wed 12/14/2016 07:44:07 PM : [std-Direct Nack] 62.43.94-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 12/14/2016 07:44:07 PM : [iNST-DUP    ] Previous message ignored.
Wed 12/14/2016 07:44:11 PM : [iNST-TX-I1  ] 02 62 3B 43 94 0F 0D 00
Wed 12/14/2016 07:44:11 PM : [iNST-ACK    ] 02 62 3B.43.94 0F 0D 00 06                 (00)
Wed 12/14/2016 07:44:11 PM : [iNST-SRX    ] 02 50 3B.43.94 30.DD.F9 A7 0D FF           (FF)
Wed 12/14/2016 07:44:11 PM : [std-Direct Nack] 3B.43.94-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 12/14/2016 07:44:11 PM : [3B 43 94 0  ] Failed to add device, reason 3
Wed 12/14/2016 07:44:11 PM : [All         ] Writing 0 bytes to devices
Link to comment
Share on other sites
Hi milhouse,
The device is sending Nacks. It doesn't like to respond to querying the engine version. Please factory reset and try again. If that does not help, make sure you don't have any older Access Points and SignaLincs and move the PLM to a different outlet.
If that also doesn't help, then the issue is most probably defective switch.
Link to comment
