Cannot Restore ISY After Factory Reset
My ISY-994i has been running perfectly for several years. Yesterday a red exclamation mark suddenly appeared before the top level ISY under NETWORK in the MAIN tab with the error message "SOCKET OPEN FAILED JAVA.NET. SOCKET EXCEPTION: NETWORK IS UNREACHABLE," Try as I may, I could not eliminate that error, so I did a Factory Reset on my ISY-994i. Now whenever I try to restore one of my MANY backups, I receive the following message: UPGRADE FAILED (REPORTED WRITTEN SIZE IS INVALID).  Any suggestions??
If it is over two years in use.
The famous PLM failure may have happened.
If you can get into the Administrative Console.
Tools Tab
Diagnostics.
What does the PLM Info/Status show? Online or Safe Mode?
