Upgrading from 99 to 994i
Hi,
Returning noob not very tech savvy - trying tp upgrade from an existing ISY 99i to 994i. So  I can add, replace etc.
Would like it to be as plug and play as possible (keep scenes, links & programs if possible).
when I plug the new 994i into the same setup -it cannot be found on the network.....so
when I plug the old one back - easily found.
I'm using a 2412 s - which still works if I can find the old 99i?
thx sdg
Hi
Just to be sure you have them, these are the directions (which don't help with your immeadiate problem)
https://wiki.universal-devices.com/index.php?title=ISY-994i_Series:Migrating_To_Your_ISY-994i
The immediate problem is most likely related to the new ISY's network presence on your network. Try this video:
The 2412s is ok to use with your existing Insteon network. Be aware, based on newer standards in the newer 2413S... it supports extended Insteon messages to access additional features and the 2412 doesn't. There are complications with going to the 2413S too, so if you are happy with your existing insteon network adn are not adding new Insteon devices in the near future, I would stick with the 2412
Give this a try and let us know what happened
Paul
Paul,
Thanks for the speedy reply - Awesome, admin console works fine - all my scenes etc transferred.
only issue is now mobilinc will not sync ? not sure what settings to change
thx sdg
Hi sdg, great!
Not a mobilnc user so not able to help with that one. If no one jumps in on that topic here, check and repost in the Mobilinc subforum. Include a link back to here if you do.
Wes is very responsive and will know what to do
http://forum.universal-devices.com/forum/35-mobilinc/
Paul
Edited by paulbates
Have you checked the Lighting Controller Settings page in Mobilinc? If your login or IP address hasn't changed, hit "tap to Sync with ISY" at bottom of page. Make sure the http IP address and port number is correct, assuming you are on your local network.
