Add logic to insteon micro on/iff
Hey there, I was wondering if one can setup a micro on/off switch so that it doesn't turn on load when somebody hits the button that triggers the sense line (ie. the switch it is behind) I can intercept the on event and then trigger an off but lights flicker then, I am trying to prevent the micro on/off to trigger the load until I ran a program. Is that possible? Cheers
That's not possible with only one Insteon device. You will need two devices, one connected to the load and one not.
