ISY Portal Offline
nathagt
This morning my ISY portal went offline around 4:01AM. I have rebooted the ISY and it is still offline. I have internet access and I'm able to log in and control devices just fine through the admin console. None of my alexa integrations are working as a result. How do I get it back up? Can't seem to find any solutions in the forum.
1. Are you seeing this off line in the Admin Console?
2. Does the ISY appear as a device in the ISY Portal?
3. Have you unplugged the Echo and waited 10 seconds and reapplied power to the unit? Once done have you rebooted the ISY Series Controller?
1. Both - admin console > portal says offline with the red flag. https://my.isy.io says offline since this morning at 4AM.
2. Yes, it is there but offline
3. Yes, I have rebooted from admin console as well as unplugging and restarting. I have also rebooted the echo.
I would suggest you submit a technical support request using this link: http://www.universal-devices.com/contact-support/
Please ensure you reference this forum post so the support staff can mark this off once completed. If you could circle back with the forum members as to root cause and end solve once complete that would be appreciated.
As an aside the portal is up and running for my controller and the Echo continues to operate just fine. I only mention this part to let you know the portal is in fact on line and operating.
I found the same thing this morning. I've tried everything, and sent a customer support email, but still nothing.
In the ISY portal if you hover over your device name, what time does it say it last connected?
Hi MNTheatreGuy,
If you have any port forwarding rules in the router that points to ISY, remove them.
If you see File | Disable Internet Access visible, click on it.
If all else fails, please reboot your router.
Thank you Michel Kohanin
Rebooted Router, which in turn rebooted ISY.. all is running again.. Not sure why that occurred but all is well now.
Now that I have resolved my insteon power line noise issues and have the Echo connected I am quickly remembering why I love this product and have recommend it to others.
thanks again.
I have the ISY powered via USB port on Router. When I bounced the router, I did so via a hard bounce and thus the USB port was no longer powered.
Possibly shouldn't do that. The ISY may come up before the router is ready to serve, causing issues. Edited by MWareman
