Programming an All Off button on a KeypadLinc
I am having trouble creating a scene to turn several devices off from a KeypadLinc button. Everything in the scene works great except for the load the keypad itself is connected to.
For example, I have Button D of a Keypad turn off 4 devices and 1 of them is that Keypads main (ON/OFF) load. The other 3 devices turn off perfectly fine but no matter what I do I cannot get the Keypads main light to turn off. The crazy part is the keypad shows the Load is off (keypad light is switched from ON to the OFF position) but the physical light is still on.
I have tried setting the Keypad as both controller and responder and neither works. Does anyone have any idea what the problem is?
Steve
Hi steve_p,
Within the scene, click on button D. To your right, change the onlevel for the load of the same KPL to 2% and NOT 0. This is a firmware issue and 2% is the workaround.
Steve
Hi Michel,
That's crazy but it worked perfectly! :lol:
Steve
  • 9 months later...
I have kpl v2c and ISY99 v2.7.0 wanted to make"a" button run a scene on and off of 4 switches including the KPL's load is there a trick? or a thread? I have seen all on or all off but not both ways? naturally everything works but the KPL's load
thx mark
